Question about Dishwashers
Door wont close - Dishwashers
    Scholar:
  • 61 Answers
Qhta is the model
is anything briken or moved alond the door or the dishwasher caseing where door connects
if auto opening switch can be faulty and if not cable may be stock
try open and relese by hand
Posted on Sep 27, 2009
FELL ONTO DISHWASHER DOOR AND NOW IT WONT CLOSE.HINGES MAY BE STRAINED.HOW DO I REPLACE HINGES
Hello friend, thank you for your post!
It sounds like it could be an issue with the hinges. I would recommend having a technician come out to your home to diagnose your appliance properly. I understand that someone fell into the door and the hinges are not closing but there could be another issue with the door. Hopefully this is helpful. -Matt
Sep 19, 2014 | Electrolux Dishwashers
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
W310 door catch wont close
need to remove the rubber around the door its a bit of a faf though
Sep 27, 2012 | Miele W310 Front Load Washer
Tappan oven door wont close
Is the door lock engaged preventing the door from closing?
Aug 21, 2012 | Ovens
Vw 2.0tdi the passenger door wont open from outside and wont always close??
Take off the door panel and check to see if the linkakge from the outer handle to the latch has become disconnected and for the closing problem lube the latch well more than likely its not opening fully when you pull the door open so when you go to close it it pushes the latch closed before the actual bar its suppose to latch to enters the latch
Dec 31, 2011 | Cars & Trucks
Door wont stay closed
Either the door catch or spring is broken, or the door lock is not working
The parts are fairly easy to fit,once you have determined what part or parts you require.
Hope this helps.
Dec 15, 2009 | Zanussi F1045W Front Load Washer
Ge profile range door wont close
was the door removed during delivery? Hinges not being fully seated can cause this. also check to see if the lock is striking the door liner, it should line up with a slot in the inner surface of the door and not touch anything unless the oven is in self-clean
Sep 01, 2009 | GE Kitchen Ranges
My 2002 town & Country Rear sliding door wont close
You need to change the locking mechanism on the door,not the theft lock that you push down by the window,the lock that keeps thew door shut.I dont know why it wouldnt lock,it must be a factory defect,that worn out before its time..
Jul 29, 2009 | 2006 Pontiac Montana SV6
Whirpool dryer wont run
inside light on when door is closed??? that sounds like a bad door switch. it doesnt recognize the door shut so it wont start, replace the door switch
Mar 29, 2008 | Dryers
My oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Jan 04, 2008 | GE Profile JTP56 Electric Double Oven
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
