Question about Dell E173FPb 17" TFT LCD Monitor
Liteview lm15w tft monitor model goes blank
When i turn on pc and monitor, the picture appears for a second and screen goes blank, power is still on, i turn it off (the monitor) and on samething happens again. I also noticed in many months that the monitor makes a zzzz noise or something similar .
Moreover, befoire this happend ,if i moved the monitor slightly i used to lose picture and i had to try to put the cable in the ac input at the back of the monitor in the correct way, when i am inserting it i noticed some noise and it takes me 5 minutes to find the correct positon. I have tried different a cable and the problems persist , i would appreciate some advice although i am no expert i would like to fix it.
I also have this monitor but mine has lost all power, tried different socket and fuse but to no avail...any ideas plz. thx in advance
Posted on Dec 02, 2009
  • flamingosex Aug 08, 2010
    My mother has the same problem as normski. there just aint no power to the monitor. We have also tried different socket and fuse.
    Please help. She really doesn't want to buy another monitor. thanx
    President:
  • 1,015 Answers
It sounds like the port where the power cable plugs into is loose and shorting out. You may be able to dis-assemble the monitor and repair or replace the port. They are usually soldered in and the solder connection may have come loose. If it plus into the circuit board you might be able to fix the plug or tighten the screw if it is held by one.
Posted on Sep 27, 2009
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Fujitsu-Siemens P15 TFT power/picture problem. it take time to turn on.
It does indeed sounds like the capacitors, I had this problem last year with a Medion monitor where it would turn on and off, when I spoke to Medion they did say that it would need a repair but at the time I wasn't enclined to pay the repair fees for something that may happen again!
Personally I would stick with your plan of getting a new monitor because my view on monitor hardware issues is that if it's happened once it will happen again even if you do repair it resulting in a lot of hassle!
May 27, 2009 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Monitor goes blank after a second after power outage
what happend is your monitor cought the brown out and the power supply capcitors are not defective and what that means is the monitor needs to be repaired there is no quick fix please rate accordenly thanks.
Apr 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
  1. No start-up. Clicking sound from speakers
  2. solution
  3. Replace C922 and C923 (both 1000uF/16V). Also replace C924 and C925 (both 470uF/16V). on powerboard
JK electronics
Den Helder
document.getElementById('showwaitmessage').style.visibility = "hidden";
Aug 11, 2008 | Fujitsu Siemens Premium Line P15-1 15" LCD...
The screen afetr minimum use
Hi John,
Its a possible loos contact in the VGA port that connects your monitor to the PC. Switch off everything, check for all possible loose connections, inside & outside the PC's cabinet, rectify if any found and restart.
If the problem still persists then there's something wrong with the Power Options Settings that you may access thru control panel. I recommend that under the First Tag i.e. Power Schemes select "Never" in all the dialogue boxes for turning off Monitor, Hard Drives & System Standby and under the 3rd Tag i.e. Hibernate, make sure to uncheck the box next to Enable Hibernation.
That's about it. I feel this should solve your problem.
May 05, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Dell E173FPb 17" TFT LCD Monitor Logo
524 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
