Question about Whirlpool GEW9250 Electric Dryer
My washer in in the lock position how do fix that
  • 2 more comments
  • alina_farina Sep 27, 2009
    My washer is in the lock position, therefore, i can not wash, is there a code
    whirpool duet, purchase two years ago
  • yadayada
    yadayada May 11, 2010
    model number please. what is code, have you tried unplugging it for 5 minutes?
  • yadayada
    make and model please.
  • 1,531 Answers
If there is still water in the tub, use a shop vac and attach it to the drain hose, unplug the unit once the water has been removed then plug it back in this should unlock the door.then i would check the drain pump for something stopping it from turning.i hope this helps let me know how things turned out,good luck
Posted on Sep 27, 2009
Fixing a matag washer that leaks how to open front of washer
you will need to take to top off and push the drum to the back and take a stubby screwdriver to remove the door lock, do not try to prise the door open, you may need to replace the door lock as it may be faulty as it should be
open in the rest position
Dec 23, 2017 | Washing Machines
Door open wont washer
Possibly some foreign object has worked it's way down into the drain pump, preventing the washer from draining. all the way. (If the washer doesn't drain properly, the door will remain locked).
One way is to take the drain hose out of the wall connection, lower it to floor level & allow it to gravity drain. (Be sure to catch the water in a pan or something). Once the washer has drained, the lid should open.
If this fixed the problem, the pump still has something in it. You will need to remove the back of the washer and check to see what's blocking the discharge pump.
Remove the back of the washer, remove the hose running to the drain pump, remove the pump itself & remove and debris clogging the pump.
Otherwise a service call runs somewhere between $100 - $175.
Apr 16, 2014 | Washing Machines
Wfw97hexl0-door is locked and won't unlock or run a cycle just makes a buzzer noise every couple of seconds.
did you try to press the stop button then change the cycle to another then press the power button then press and hold the start button again that works most of the time.
Mar 11, 2013 | Whirlpool Duet WFW97HEXL Lunar Silver...
I couldn't get the washer to start (HE 4T). It
DL stands for Door Lock failure, if your door isnt closing all the way, check to make sure your hinges are lining up and that one of the arms has not broken off on the door, there should be 2 arms going into the door lock. whats common on these is that the door latch has trouble unlocking so it is forced open and now the door latch mechinism is stuck in the locked position and cant re-open. problems with this lock opening and closing- 9 times out of ten, come from a main computer failure to send power to the door lock. this can be temporairily fixed by re-seating the door latch wire harness in the main computer, but its usually recommended to buy a new computer since this problem has been address on the new series of computer. there is no recall on this board at the moment. estimated cost $250-$400
Nov 24, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Mar 15, 2009 | Hotpoint WMA31 Front Load Washer
Error F dL?
remove the top cover of washer at rear is the main control bd try wiggling the wires on front side usuually the larger wires if it works bad connections on control no fix but to replace it ..HOWEVER try shimming the plugs in place to hold them in position where it will work...possible door lock itself but control more likely
Sep 06, 2008 | Kenmore 46462 Front Load Washer
Frigidaire gltf1670as0 Front Loading Washer
door lock position switch may not have been properly tightened at factory. first position then tighten the switch
May 11, 2007 | Frigidaire GLWS1233A Top Load Washer
Whirlpool GEW9250 Electric Dryer Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
