Question about Lands Phones
I need aristel av20 command and programming manual
M-Audio AV20 smells like burnt
Yes, it is possible to burn an IC and not the fuse, because of Safety standards, the fuse has the function to avoid a possible fire, but it should deliver all the power needed by the circuit it is protecting, and that amount of power can burn, in this case, the IC.
From my technical point of view, there should not be a problem to connect the speaker to 110 V instead of 220 V, all that might happen is to have less power available at output, I have no idea about the reason of the burnt IC, but, as we all know, they (the IC's), don't need a reason to burn themselves whenever they decide to.
So, the next step, will be to replace the burnt IC, and that is not a simple task, you need a SMD station and some experience in doing such jobs.
Good luck and best wishes.
Apr 11, 2013 | M-Audio AV20 STUDIOPHILE
I need the programming codes for TEAC Dolby HX Pro. I have a Sony Remote Commander which can access up to 8 components, but I don't have the instruction book containg the codes. I don't really need the...
First to clarify: are you programming the Sony Remote Commander to operate the TEAC? The AIR-RM10 (S-AIR Remote Commander) only operates Altus S-AIR transmitters and receivers. The code needs to be physically set in the battery compartment to have the units working on the same frequency. Then you pair or couple the devices (so there is no remote code involved). Other Sony device remotes only operate Sony brand products. Would you please clarify which remote you have? I'll be glad to check if your devices can be paired with more information.
Manuals (and codes where applicable) are available for most Sony products here: http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS&PRODTYPE=32 . You will need the model number of the Remote Commander to find your manual.
Note: the codes programmed into most remotes are limited to those for devices released at least 6 months before the remote was programmed. If your remote is older than the TEAC Dolby HX Pro, you may need a newer remote (or a different remote).
Please write back and I'll give you as much help as I can.
Mar 06, 2011 | Teac Televison & Video
Hotel
It needs to be re-programmed to use your TV. Here is the manual link. Follow it to program the remote for you TV make.
http://audiovox2.info/docs/rca_acc/man/RCR350_DOC_OM.PDF
Jul 05, 2010 | RCA RCR350 Remote Control
How much are the panasonic SV-AV20 digital cameras
ive seen prices ranging from $70(used) to $299(new). it just depends on where you buy it, and if you buy it new or used. hope it helps!!
Dec 18, 2009 | Panasonic SV-AV20 Digital Camera
Dell inspiron 1525 keeps freezing
next time your computer starts go to a command prompt and type chkdsk/f it will ask you if you want to run chkdsk next time your computer starts ..say yes..and then restart the /f command repairs damaged sectors..that might help..
Nov 07, 2009 | Dell Inspiron 1525 Notebook
How do i upload pictures from the panasonic sv-av20
According to this description on Amazon, your model uses SD memory cards:
http://www.amazon.com/Panasonic-SVAV20-Digital-Camcorder-Camera/dp/B00008OLBN
Then you should have 2 options:
(1) The easiest is to remove the SD memory card from the SV-AV20 and insert it into an SD card reader (many available, starting from below $10). The SD card reader will have a USB connector so you can plug it into a USB port on your computer. Your computer (Windows or Mac) should recognize that you've inserted this and show the data on the SD card as a removable storage device.
(2) Clunkier option is to use the USB cable that typically comes with digital cameras -- these require the camera to be turned on. If you're unlucky, you may have to install camera-specific software on your computer to recognize the device. Since I hate adding extra software to my computer, I far prefer option #1 above, which works universally.
Hope this helps.
Aug 13, 2009 | Panasonic Cameras
NEED MY ROUTER IP ADRESS CANT LOCATE MANUAL MODEL F5D9230-4
This is from the Belkin Web Site:
Windows 2000, XP, and Vista
1. Click Start, and then select All Programs (XP and Vista) or Programs (2000). 2. Select Accessories, and then Command Prompt (2000, XP, and Vista). 3. At the command prompt, enter: ipconfig 4. The IP address (or IPv4 address is you are using Windows Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx, for example, 192.168.2.2. 5. To close the command prompt, type: exit and press Enter.
Jun 19, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Make Softwere
hi
am programer in vfp9.0 you need to download manuals and examples
y have many
Apr 24, 2008 | Microsoft Visual FoxPro 9.0 Professional...
Music + 2 Gb-sd-card = ?
Just an FYI, I bought a 16 GB SDHC card for my eware (Panasonic SV-AV20) and found out that the highest compatible card for this device is only 1 GB! (according to http://panasonic.jp/support/global/cs/sd/connect/d_snap/sv_av20.html). I kept getting a "CHECK CARD" error so I know it won't work. You might want to see if your devlice is listed on a similar chart.
Apr 08, 2008 | Panasonic SV-AV20 Digital Camera
Net Command Does not work
Go to net command menu click on the AVR Learn icon.
Now you can program 4 different functions (inputs) from another remote. I programed 4 different source settings from my A/V receiver. And you label each input appropiately. Such as DVD, SAT, CAB, ANT.....
Now go back to net command and just to the right of previous Learn Icon you input the name of the source you just programmed for which ever device it is currently watching.
Net command is very confusing but works great once you figure it out. Hope this helps.
Jan 28, 2008 | Mitsubishi WD-65833 65" HDTV
Lands Phones Logo
541 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
