Question about Vacuums
Kirby intermittent power, sparks near foot switch, how do you remove switch? Coud just be a loose connections?
    President:
  • Vacuums Master
  • 1,922 Answers
Lay handle down toward floor and remove case top screws and replace the switch you'll be money ahead
Posted on Sep 27, 2009
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
My Heritage II just lost power in the middle of vacuuming. The switch will turn on but no power.??? What is wrong?
It could be the switch that has become defective (the 'feel' of the switch may be different, but needs to be checked with a meter). Another possibility is that the cord has developed a loose connection at or near the power plug. Turn the switch on and wiggle/push the cord near the plug. An intermittent connection is indicated by the motor turning on and off. If so, cut the plug from the cord (they are usually a molded device that can't be serviced) and install a replacement plug from a hardware store or home center. If the switch is determined to be bad, order a new one from an appliance parts store or vacuum repair center. Good luck!
Feb 20, 2010 | Kirby Heritage II Vacuum
When i press the foot switch the machine does not switch on. Is there an internal fuse?
Don't think there is an internal fuse.
If you have replaced or tested the plug top fuse & that's ok, it may be that the foot switch needs replacing or a wire has come loose from it.
Nov 18, 2009 | Kirby Heritage II Vacuum
My kirby generation 3 wont come on
Make sure cord is not damaged. Check to see nothing is blocking hose or carpet nozzle(where beater brush is or brush roll). Plug unit in to a receptacle that you know has power going to it. (Lamp you know works when plugged into same. Using hose on front, make sure bag bottom completely attached to exhaust, the hose has a little arm like thing that will depress the safety switch on the front of the unit, and turn on using foot switch at the back of the unit. If these do not work, it could be one of two safety switches, dirt may have fouled or switch may need to be replaced. Authorized Kirby Dealer in your area: Replacement parts, Kirby Distributor, call: 1-800-437-7170 United States and Canada
Nov 01, 2009 | Kirby Generation 3 Bagged Upright Vacuum
My kirby legend II started spitting out sparks near the foot plug. How can I fix it please? Thanks Candy
Depends where the sparks are spitting from.Unplug from the wall and try to detach the cord from the vac itself, where it plugs in. If there is a small hole burned in the side you will need to detach the entire cord from the handle where it clamps on and buy a genuine new one from a vac repair shop or Kirby dealer. Cords do wear out. Ther is a slim possibility you could have a bad switch below but generally the switch just dies , no sparking.
If the sparks were shooting out from inside the motor housing, you will likeley need a motor rebuild which should be done by a professional at vac shop.
Oct 04, 2009 | Vacuums
No power from Kirby!!
Determine if the headlight works before anything else. If the light works but the motor won't you have power thru the vac and the problem is internal possibly motor brushes... or a loose wire on the inside connecting to the switch.
If the light goes out is likely a switch or cord problem. Switches on these vacs break more often than cords. What you see on top is the switch button, not the actually internal switch, however a switch does not normally fail while the vac is running, that sounds more like a loose connection or a bad cord.
So isolate the cord. Unplug it at both ends and plug lamp ( or test meter) into the cord into the cord and gently wiggle where the plug end meets the cord. If the lamp goes on and off the issue is the cord. You can buy a replacement specific to the Kirby series and plug it in yourself. If this s does not isolate the problem, take it to a service center. Kirby is very intricate inside.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
The foot switch does not turn on the G4D Kirby vacuum cleaner.
Here's a link to a free guide! The switch is available at this site as well...there is a link in the guide to buy one.
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope this helps,
Marci
Aug 05, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby G5 intermittent power
I would say that it is a short in the power cord.
Try my troubleshooting guide. It helps with do-it-yourself Kirby repairs. You'll also find links to directions, parts (cords too!!) and free repair guides!
http://reviews.ebay.com/COMMON-PROBLEMS-WITH-THE-KIRBY-VACUUM-TROUBLESHOOTING_W0QQugidZ10000000003800312
Jul 31, 2008 | Kirby G5 Bagged Upright Vacuum
No power
I'm not familiar with Kirby vacuums, but press your reset button a few times (if you have one). If that does not work, then it is most likely the switch. For a rough estimate of the switch or parts for your vacuum, please refer to Sears Parts website and have your model number ready.
Sears website: http://www3.sears.com
Mar 07, 2008 | Kirby G5 Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
