I have a Whirlpool coin operated top load washing
I have a Whirlpool coin operated top load washing machine, the coin slot is jammed and won't go forward or come back, please help!
    Scholar:
  • 61 Answers
I hate this
try insert another coin
if not you will have to run a wire through and a frictioned and magnetised coin might help
if you can you will have to dismantle this part in trying to release it
Posted on Sep 27, 2009
Whirlpool commercial top load coin washing machine with only Luke warm water
i would take hoses off washer and check screens infill valves first.valve may have a thermister in it to control water temp this may be bad.may have to call a tech.
Dec 10, 2013 | Whirlpool CAM2752RQ Coin Operated...
Money fell under the spinner
I take it that you mean that there is monetary coin or coins stuck between the Wash Bowl and the Spin Bowl. If the diameter of the coinage is greater than the Wash Bowl outlet, the coins will never find their way to the emptying pump of the machine, and will continue to rattle around inside. However any of the coins can enter the Wash Bowl outlet this could result in the water pump becoming jammed or damaged requiring replacement. I have solved this problem by removing the top of the machine (HOB) above the washbowl then completely removing the shroud over the Wash Bowl...then replacing the top of the machine firmly. By then turning the machine upside down, the coins will drop out and can be retrieved. Finish the job by returning the machine to the upright position.
Oct 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I change the amount for my coin operated Whirlpool top loading washer?
weight slot should be adjustable. Acts like a lock tumbler. Not enough pins move and the lock will not open. Reduce the number of pins and the lock will open sooner.
Feb 25, 2010 | Whirlpool Washing Machines
Just bought brand new commercial coin operated washing machine top load...everything is level tried washing a load and at the spin cycle the machine vibrates so bad it seems like it's going to take off. ...
maybe when you were moving it, one or more of the springs that keep the drum centered came off,unhook everything,drain it,tip it over face down on a piece of clean carpet, make sure everything is in order,all supports are in place, 2 people to tip it
Jan 31, 2010 | Whirlpool CAM2752RQ Coin Operated...
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
Machine not starting
These machines are owned by a company or your Landlord you will need to contact them for the repair on the Coin slide
Jan 28, 2008 | Maytag MAT12CS Top Load Washer
Whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Sep 06, 2007 | Washing Machines
Washing Machines Logo
544 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
