Question about Cameras
Error on Nikon D40 when powering on with any Lens set to Auto Message ''error turn camera off and then on again''. Does not happen when the lens is set to manual.
D40 Nikon
i have the same problem..only it seems mine has been caused by a piece of plastic off my lens somehow falling behind the shutter and impeding its use.I wouldn't recommend you poking around the shutter but you could remove the lens to have a look if the optics is damaged.Bringing it to an authorized dealer might be the best way to go !
Feb 21, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
D40 "Error: press shutter release button again." Nothing happens.
If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
Dec 19, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
After inserting lens it keeps saying lens not attached
I would help to know the error message, but here is what I can tell you.
Having a "Lens error " message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day.
Oct 31, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My d40 gives error message "error press shutter button again"
When do you get this message? Is the Mirror Lockup on? If not, try to take the lens off and screw it in again.
Jan 24, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
R09 error message on nikon d40
It's a report saying that the camera is busy doing something. It can hapen when you have taken a photo and the camera is busy processing but I find it happens when in auto focus and the camera is having dificulty due to distance from subject or light. Try switching to manual focus, moving further away from the subject or casting more light on the subject.
Oct 29, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Apr 15, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 Error Message
Get the kit changed. That should not happen right out of the box, but make double sure the next time around, you charge the battery completely before using it the first time. Not doing this can cause problems.
Nov 18, 2007 | Nikon D40x Digital Camera
Cameras Logo
173 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
