Question about Gateway Computers & Internet
Hard drive issue
Hard disk drive smart status bad error message
    Problem Solver:
  • 45 Answers
Hard drive will not boot up
Posted on Dec 14, 2009
  • 3,153 Answers
This tells you that the drive has a problem and may be due to fail shortly.
You can either clone the drive to a new (possibly larger) drive
Save your important files while you still have chance and put a new drive in re-install your operating system and copy your files back
Or wait and risk total failure and loss of data.
My option would be the first one
Posted on Sep 28, 2009
Western digital error code 1117
It's an I/O error. It could be a thermal issue, a connection issue, or symptoms of a disk failure. Reseat the hard drive and cables if used. Then Run WD Data Lifeguard Tools on the drive to see if there are SMART errors. If the drive fails the diagnostics, check the warranty status to see if you are eligible for a free replacement.
Feb 02, 2014 | Computers & Internet
Hard disk smart capable status bad
SMART is a hard drive utility built into some computer bios'. SMART is informing you that the hard drive is bad.
Jan 20, 2014 | Toshiba MK6028GAL 60 GB EIDE Hard Drive
Pri master hard disk s.m.a.r.t. status bad, backup and replace press del to resume
Hard drive is bad or is going to fail soon.
Solution
Backup your information and contact the maunufacturer of the computer or the hard drive for replacement or additional help.
In some very rare cases the S.M.A.R.T. implementation on your computer may have issues of its own and may need to be patched before replacing the hard drive.
If I am receiving the S.M.A.R.T. error, is it ok if I continue to use my hard drive and do not replace it?
As stated above, S.M.A.R.T. is designed to detect upcoming failures in the hard drive.
While it is possible that the hard drive may not fail for several months, it is still inevitable that the hard drive will fail.
It is ok to continue to use the hard drive, however, we highly recommend that if you are still under warranty that you consider getting the drive replaced before your warranty runs out.
hope this helps
Sep 20, 2012 | Western Digital WD AV WD2500AVJS hard...
When pc boots My wdc hard disk shows sec master hard disk S.M.A.R.T status bad backup and replace
your hard disk getting damage so take back up fast and replace hard disk with new hard disk smart test when hard disk want when hard disk surface going some hardware problem
May 22, 2012 | Western Digital Computers & Internet
How do i get rid of the KERNEL_STACK_INPAGE_ERROR on my d600? Occasionally it says UNMOUNTABLE_BOOT_VOLUME instead. Help?
This issue can occur if a requested page of kernel data could not be read from the paging file into memory, or the master boot record is infected with a virus. To further determine the possible cause, you must properly interpret the error message. If both the first and third parameters are zero, then the four parameters are defined as:
  1. 0 (zero)
  2. Page Table Entry (PTE) value at time of error
  3. 0 (zero)
  4. Address of signature on kernel stack
If either the first or the third parameter is not a zero, then the following definitions apply:
  1. Status code
  2. I/O status code
  3. Page file number
  4. Offset into page file
If this is the case, the cause of this issue may be determined from the second parameter (the I/O status code) by using the following information that is listed in a "value of second parameter" followed by "general cause" format:
0xC000000E, or STATUS_NO_SUCH_DEVICE: the drive went unavailable, possibly a bad hard drive, disk array, and/or controller card.
0xC000009A, or STATUS_INSUFFICIENT_RESOURCES: lack of nonpaged pool resources.
0xC000009C, or STATUS_DEVICE_DATA_ERROR: bad blocks on the hard disk.
0xC000009D, or STATUS_DEVICE_NOT_CONNECTED: bad cabling, non-termination, or the controller is not able to obtain access to the hard disk.
0xC000016A, or STATUS_DISK_OPERATION_FAILED: bad blocks on the hard disk.
0xC0000185, or STATUS_IO_DEVICE_ERROR: improper termination or defective cabling of SCSI-based devices, or two devices attempting to use the same IRQ.
To resolve this issue, use the appropriate method:
Boot sector virus loadTOCNode(2, 'resolution'); To determine if you have a boot sector virus, run a current virus-checking program, and if needed, disinfect your computer.
Not a boot sector virus loadTOCNode(2, 'resolution'); View the System Log in Event Viewer for additional error messages that help you determine the device that is causing the error.
Bad block. Stop 0x77 is caused by a bad block in a paging file, or a disk controller error, or in extremely rare cases it is caused when non-paged pool resources are unavailable.
If the first and second parameters are 0, then the stack signature was not found in the kernel stack. The cause of this issue is defective hardware. If the I/O status is C0000185 and the paging file is on a SCSI-based hard disk, you should verify the disk cabling and SCSI termination.
If the I/O status code is 0xC000009C or 0xC000016A, this normally indicates that the data could not be read from the disk due to a bad block.
If you can restart your computer after the error message, Autochk runs automatically and tries to map out the bad sector. If for some reason Autochk does not scan the hard disk for errors, manually start the disk scanner. If your computer is formatted with the NTFS file system, run Chkdsk /f /r on the system partition. You must restart your computer before the disk scan begins. If you cannot start your computer due to this issue, use the Command Console and run Chkdsk /r.
Defective or unreliable random access memory (RAM) is another common cause of this issue.
Verify that all the adapter cards in your computer are properly seated.
Ensure that all adapter card contacts are clean.
Disable system caching in the BIOS to see if this resolves the error.
If this does not resolve the issue, your computer mainboard may be damaged.
Oct 23, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Bad hard drive?
the hard drive is damaged. install a new hdd and connect the old one as a secondary so you can extract your files after you reload the new one.
Mar 28, 2009 | E-Machines T3065 PC Desktop
Hard disk error
Unfortunately this error occurs with a fault hard drive. You will need to replace the hard drive and then reinstall the OS.
Mar 20, 2009 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Disk error searching for boot rercord from CDROM not found
Hi rmirish,
The hard drive has built in SMART diagnostics to check itself to make sure all is well. If the SMART is showing status BAD then the hard drive is either either starting to go out. Your best bet is to try to backup any data (if you have any) on the hard drive and replace the hard drive.
Hope that helps,
Take care,
Michael
Nov 17, 2008 | NEC Computers & Internet
ACER SMART failure
SMART means self monitoring and reporting tool, this is the option which performs certain test for the status of hard disk health, if its coming it means condition of your hard disk is not good, its better if you immediately back up your data and replace it, by the way you can also disable this warning through the bios, just disable the smart feature in hard disk
Nov 10, 2008 | Acer Aspire 3680 Laptop
Compaq laptop C310 T1300
here's what you should do.. first, as mentioned, you should backup all your important files in another drive or an optical drive... once you have done it, format your hard drive and perform scans to check the error.. during scan, you will see errors on it and you may not be able to fix it since the drive is internally damaged.. purchase a new one ok? just make sure to backup all your files..
Jan 23, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
133 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
