Question about Whirlpool Duet GHW9150P Front Load Washer
Our Whirlpool Duet GHW9150P washer will not get off error 40 and it just keeps sucking water out even when there is no water left. And it will not cancel the mode and unlock the door. So I don't have the model exactly, but I'm pretty sure this is it.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$#%
Posted on Sep 30, 2010
What is an f20 error code mean?
this is known code even for washers straigt out of the box it mean there is a problem with water pressure. ensure the water supply is connected and on.
2 there is a Analog Pressure Switch located underneath the top cover in the back left corner of the washer next to the CCU it may have come loose find and reconnect if not it maybe defective.
replacement part no is w1o156252
3 possible flow meter is defective part w10110225
4 also check the internal hoses for leaks even a pin sized hole can cause the code to show up.
I hope this was useful.
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Oct 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an E1 Error code on my Whirlpool Duet dryer. Technician came and didn't fix it. Any suggestions?
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer. water is in drum.
Yes, there is a solenoid based water inlet valve device located inside the unit on the back top left or right side. this valve is damaged. replace it asap.
Jul 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Started Duet without water turned on. Now have error code.
go here and find your manual this will help
www.whirlpool.com.au
Jun 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cold water keeps filling even when washer is off
if it still flows with the unit unplugged then replace the cold side inlet valve for the fix , it my be called the mixing valve on a part search. Phil
Jun 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Detergent reservoir won't drain after cycle finished. Water stays in it.
hopefully your using the HE type detergent an fabric softner, an not using but a teaspoon full each. the machine will detect if there is any product left in depenser. an too there will be some water left to keep lines an seals mosit. to keep from drying out so thats normal.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
