Question about Brother MFC 210C All-In-One InkJet Printer
P aper jamed under printer head cannot get it out
Head strucked in the left side of the printer
Printers are made of plastics, even those expensive looking and probably some piece has weared off. My experience is that this kind of failure can't be repaired by a user vithouth the repair kit and the technical knoledge. If you don't know how - most probably - you should take your printer to an authorized Epson repair site.
Apr 17, 2015 | Epson Dot Matrix LQ-300+II Printer
MMY COPY MACHINE IS CSPRO MODEL EP 3010 MINOLTA APER ERROR CODE C061
Lens Motor, under the big glass is to your right is the lens assy. there is a motor that works the mirrors on that side it is either jammed or burned out. Or worse case the board controlling it is bad. You have a Legacy Minolta Machine, get a tech out (Old School one:))
Jun 02, 2014 | Konica Minolta Office Equipment & Supplies
My printer brother DCP-J 125 is not print
my printer head is jamed how to clean head ?
Oct 21, 2012 | Brother DCPJ125 DCP-J125 Inkjet...
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
I am having a problem with paper jaming nothing seams to be in there but it tells me there is a paper jam
when turn on the status is ready? But when start printing status go paper jam? The problem is head, try to replace head.
Jun 10, 2009 | HP Photosmart 3310 Printer
Continual paper jam: canon mp830 - error 5100
follow the following:
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Thanks
Mar 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have j1045 front load samsung 7 kg washing machine it shows 5E message and its not draining properly.we cleaned the filter, and drainage hose is not jamed.what should i do
The display should say 5E, this means that it's not draining. unlucky for you as this means you have to replace the drain pump, wich aperently cost about $137NZ. this seemes to be a common fault. i'm not a teck, but I just had the same thing happen, lucky for me i had a warranty.
Other simptoms are the loud racking noise coming fromn the washing machine. home this helps.
Jun 21, 2008 | Washing Machines
Pictures are green
some ink delivery vesseles could be jamed
try to clean the cartige holder with a glass cleaning solution pour so the liquid makes its way and open the jamed tiny tubes which delivers the ink then dry it with a piece of cloth
Jun 01, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
19 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
