Question about Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range
No heat from the baking element in the oven
No heat, replaced the element and it made no difference. The electronic control panel clicks, like a relay click, every minute or so. Broiler element works fine. I am thinking of replacing the electonic control panel since the relays seem permanently attached and I would need to replace the whole thing.
  • Tswany101 Dec 18, 2007
    I am a little frustrated since the control panel does all the other functions fine--it just seems like a waste to replace it all for a bad relay--
  • 482 Answers
I beleave you are right.
Posted on Dec 18, 2007
  • farren wadley
    farren wadley Dec 18, 2007
    no it well fix the part that does not work.
JTP86-30 Oven is not heating. Neither element in the oven heats. I can hear the 'click' I'd expect when it starts to heat. The fan starts up and the readout shows 100 degrees. It never changes and the...
Many GE oven control boards have a relay for the common of the broil and bake elements. This relay is notorious for being the culprit. the electronic control board will need to be replaced. You could check with to see if the control can be rebuilt. It is much cheaper but you will have to send the board to them for repair.
Mar 28, 2014 | GE Wall Oven Plus Microwave - Model...
Replaced oven element still not heating up
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
Feb 15, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
I just replaced my baking element in my oven, and when i turned the breaker back on, now the new element automatically heats up by itself and stays on....with everything off. The only way I can get it to...
If the only wires you disconnected and reconnected were the 2 on the element itself, the bake relay is fused. Depending on the brand and model, the bake relay can be located on either a realy board or the electronic oven controller. Either the controller or the relay board (if present), will also need to be replaced.
Apr 16, 2011 | Stoves Ovens
Top oven not baking correctly. The bottom element get nice and red but the to isn't so bright, making brownies last night oven at 350 and I pull the rack out during baking to put PB chips on them and...
How proficient are you with electrical wiring and electronics?
Just as a test to see if both elements are working, very carefully use a very damp (almost but not quite dripping) to touch the elements when the oven is just turned on. My problem was with the lower heating element, it was not heating. You have to do this before the oven heats because everything will be hot then.
After verifying it was not heating, I unplugged the oven and opened the back panel. I removed the leads from the malfunctioning heating element, attached the alligator leads of my volt meter, plugged the oven back in and turned oven on at 100 deg F; this will establish a potential. I measured voltage and got 26 VAC when I should have had ~240 VAC.
I swapped the orange and tan leads and saw the top element not work and the bottom did. Looking at the wiring diagram, I traced the problem to a relay on the control panel.
At this time I don't know yet if I can find a switch to replace the defective relay or if I need to replace the whole control panel. I sure hope I can replace the relay because the control panel will be ~$300.
Mar 31, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Broiler element not working at all. checked element--it's OK. Called a serviceman-- he thought it was an oven sensor--replaced sensor ---no change Electronic clock some times shows a code "F2 ...
you do not say it is electric oven. if so broil element requires 240 vac. may be controlled by relay. Is bake element working? also controls for broil may be different setting if digital panel is in this design. I think same sensor may be used for bake or broil.
you do not say if gas oven, electric oven, single or double oven or if digital panel control, a little more information would help.
if you have digial voltmeter, FULLY disconnect electric power and measure element on terminals. probably less than 15-20 ohms for a good element.
Dec 28, 2010 | Ovens
Replaced heating element in oven but still remains on.
When the bake element shorted out, did the element make a big bang and perhaps even short against the metal bottom of your oven? I am suspecting the relay on your electronic oven control shorted and fused together. With this in mind, unplug the oven and gain access to the electronic control. Now trace the wire going from the electronic control to your lower bake element. Once you have figured which one it is, remove it from the electronic control. Tape it off with black electrical tape and plug the oven back in. At this pint, the element should not come on. Dis it come on or is it off. If off, replacing the electronic contro is the next step or if handly enough, you can replace the relay on the control...Let me know if I can help further.....
Eric Campion
Feb 14, 2009 | Hotpoint RB787 Electric Kitchen Range
Bake element doesn't turn off
The relay controlling the element has likely failed and welded it self closed. This parts is normally built into the electronic control board, which costs somewhere around $200 to $300 to replace.
Try for the part. If are not familiar with repairing appliances, you might want to refer this to a professional.
Jan 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Kenmore Stove and the bottom (bake) element does not heat up. The top Element is fine. I have replaced the bottom element and checked the fuses and they seem fine. Could it be a control panel that...
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
May 28, 2008 | Kenmore Kitchen Ranges
Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Feb 11, 2008 | Amana AOCS3040 Electric Single Oven
Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range Logo
200 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
