Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Does GE Profile TFX27PF have a water filter? - GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
jcpark50
  • 52 Answers
SOURCE: GE Profile TFX27PF/TFT27PF Refridgerator
There is a line from the defroster catch pan, up under the freezer, to an evaporation pan, down under the bottom. If it becomes clogged with dirt, bugs, whatever, the catch pan will overflow, and leave a puddle on the floor. Find it and unclog it.
Posted on Nov 07, 2008
  • 219 Answers
SOURCE: warm temp
u have a defrost problem if u shut it down 4 or 5 hrs with doors open then turn back on itll work tii u have it fixed
Posted on Mar 24, 2009
  • 311 Answers
SOURCE: ge profile arctica side by side- ice maker and
The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
Posted on Jan 11, 2010
  • 531 Answers
SOURCE: smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Posted on Mar 31, 2009
Sea Breeze
  • 4655 Answers
SOURCE: no water, no ice, but new water filter cartridge
If it was running before the filter change you need to purge the filter cartridge of the air in the lines. Also check voltage on the back on the water control valves . While someone presses dispenser you should get 120volts AC on the plug receptacle side for the dispenser . Let me know what you find, Sea Breeze
Posted on May 19, 2009
Where can I find a part number for a GE TFX27PF filter for the water dispenser?
Your model does not have a water filter. It is not hard to install an "in-line" filter, like the one pictured below, on the water supply line before it reaches the refrigerator water valve...
Jul 20, 2016 | GE Refrigerators
I need the part number to replace ice maker in GE Profile TFX27PF or TFT27PF
The replacement part number is WR30X10093 it is GE's newest electronic icemaker,all newer style icemakers and designed to also work for older models such as yours
GENE
Sep 17, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
ESTOY EN VENEZUELA EL DISPENSADOR DE AGUA Y HIELO NO FUNCIONA (MODELO TFX27PF REFRIGERATOR-FREZER QUE PIEZA NECESITO PARA SUSTITUR (SERIAL)
You would want to first check your water valve. It is a dual water valve. I suspect your solenoid for the water in the door has failed. Let me know Amigo.
May 22, 2011 | GE Refrigerators
I just installed a new MSWF water filter cartridge on my GE Profile refrigerator. After pushing the reset button, there is no water flow at all. I can hear the pump humming. I tried removing and...
Tried new filter. Thought water line frozen. Problem solved by bypassing the water filter. Now that I'm working without filter I will troubleshoot the filter receptacle.
May 04, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Warm temp
Mar 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Smelly water dispensed from ge profile refrigerator
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
891 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
