I have a JVC tv, model number AV-29RS and i have this problem that there is the channel number that comes up on the top right hand side of the screen in a gray box and wont go away. The only way i can get rid of it is by pressing the MENU/OK ON THE TV THEN SELECTING DEMO AND TURNING IT OFF. But when i change the channel again the gray box comes back and i have to do the same procedure again.I don't have the original remote but i have a universal. Please help
    Scholar:
  • 61 Answers
This happens as the wrong code on the remote control is ther
cab you reset it and authomatically change it into another code
try other code Phylips may do as Itt also
try and buy another remote comtrol as sometimes other works better as it seems your is getting stuck
Posted on Sep 27, 2009
Video channel "v" In right hand corner
All depend of the design of the TV and REm CONTROL. See you owner manual or download from www. retrevo.com
God bless you
Oct 18, 2012 | JVC AV-27820 27" TV
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
Sep 23, 2009 | Televison & Video
Number won't erase
Press the "DISPLAY" button. This may cycle through a couple of other displays but will finally clear the channel number. (That's how it gets turned on, too, by pressing that button.)
If this solution is what you needed, please take a moment to rate it. Thanks for asking here!
Feb 20, 2009 | JVC AV-27530 27" TV
Tv will not recognize channels to save, goes to black screen
If you want to get the original remote for this model (AV-30W776), you can find it at this JVC parts ditrubutor:
JVC AV-30W776 Replacement Part Remote Control
Jan 09, 2009 | JVC AV-30W776 30" TV
My jvc av 32230 has no chanells only blue screen
what you need to do is go into the menu and select the channel program, so the tv will find any channels that are coming through the cable line. so make sure the input is set to cable and tv.
Dec 16, 2008 | JVC AV-32230 32" TV
Jvc projection tv
try this site http://www.sharefx.net/index.php
Jul 16, 2008 | JVC AV-56WP74 56" Rear Projection...
Can't change channel
Most remotes have the source button at the top right hand side all the top left hand side it should be called sauce or it might just have three lines if you have a black lever on the right hand side then you need to press that in and wait it should put you to the av screen then if you let go you can press down or up that will let you chose av or video of hdmi ok if you want to send me a pic of the Tv so I could help you more if you can't find it I don't mind ok
Jul 10, 2017 | Toshiba Televison & Video
JVC Channel Code locked and need to unlock
The square box is not a channel lock it's closed caption and labled CC in your menu.. Go into the menu and set CC off... No more box...
Jan 27, 2008 | JVC AV-32020 32" TV
Tv
please clear it. not easy to understand.
Sep 27, 2007 | JVC AV-32120 32" TV
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
Electro Med Services...
