Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a Cub Cadet that stops running 10-20 seconds after start up. It was left out during a hard rain(if that helps). Any suggestions on how to solve this problem.
  • 437 Answers
The rain may have put enough water in the tank to make it not want to run.
Draining the fuel out of the bottom of the tank may help get the water out of the tank. A product like "seaform" gas addictive will help clean out the moisture out of the tank.
Posted on Sep 30, 2009
How can I get the cub cadet xt1 to run/start without mower deck installed?
Sit on it, push the left pedal down and it should start.
Dec 11, 2016 | Cub Cadet Garden
Rzt 50 cub cadet stops running after 5 seconds
fuel problems. start with fuel lines, filter. if that don't solve it take the carburetor off and clean it real good. maybe a carb. kit they are cheap.
Nov 04, 2016 | Cub Cadet Garden
My cub cadet tiller works great in soft soil, but will stop tilling in harder soil
with out having to many details sounds like a worn belt if it's old or a miss adjusted tension spring if it's new
May 18, 2016 | Cub Cadet Garden
After cutting the grass with a Cub Cadet 1050 after it set for hours the engine
check for water in gas espeially if you leave outside in rain try shooting some starting fluid in it see if it starts up drain gas and fuel lines install new gas fresh not same gas
Sep 02, 2014 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
Cub cadet starts and then quits
you should see some gas in filter no usually full though
Jul 27, 2013 | Cub Cadet Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
MY PUSHMOWER WILL START AND STOP AFTER ONE MINUTE
An engine that will start, but will only run for a short period of time will often have one of the following causes:
*Defective or inoperative choke or primer.
* Water or dirt contamination in fuel system.
* Broken, cracked, or clogged fuel lines.
* A dirty fuel filter
* A carburator out of adjustment.
If this usually happens during cold starts, then you may have a situation where the primer or choke is not working properly.
Check the cap on the fuel tank and make sure that it is vented properly.
I sure hope this helps you and good luck.
Jul 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Problem with left side hydrostatic transmission
This is a well documented problem with cub cadet ZT transmissions. They tend to go bad after 200 hours of use. Sometimes having the dealer change the transmission oil will help (they need to remove the transmissions to do this!). Most times, the transmission is gone & must be replaced ($800-$900).
Sound to me like a design defect. My ZT-50 lasted only 4 years. Needless to say, the replacement was not a cub cadet.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
336 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
