Question about Car Audio & Video
The front face i put it down and when i put it back up it wont stay up
    Scholar:
  • 61 Answers
It happened to me
at the back ther is a pin check that it is lose and if you can open the back and reset the pin
this may help
Posted on Sep 27, 2009
My brakes stay stuck and the car wont move
sounds like your emergency brake cables are stuck raise your car one wheel at time starting with the front (block the back wheels for safety) put the car in neutral and see if the front wheels spin by hand if so the e-brake is the problem try rocking the brake handle a few times if that dont do it put the car back down find the cables under the car and try to move them around the cable may release itself doing this
Apr 18, 2012 | 1994 Honda Accord
JVC KD-AVX1. The head unit will not "turn on" when the power button is pushed. The display just stays off. The face lights up when you press the eject button and opens up and you are able to feed...
is this a headunit you have just installed? if not then I am not sure, but if it is, try swapping the red and yellow wires over. One should have permanent live, the other should be switchable. (unless you want the headunit to stay on when the ignition is off, in which case put them both to a permenant live feed.)
Hope this helps.
May 09, 2011 | JVC KD-AVX1 Car DVD Player
How do i change from Samsung keypad to qwerty keypad on a Samsung mesmerize?
hi if you hold the phone in front of you in upright position so the ear part is at the top on the bottom of the phone is at the bottom pointing downwards then all you need to do is rotate the phone anit clockwise so the ear piece is pointing to your left and the speaker facing the right you need to hold the phone upright though if its flat like is lying down then it wont change to qwerty keyboard it needs to be like, say you have a photo on a shelf but the photo is on its side in landscape view thats how u need to hold the phone, if the back of the phone is facing the floor it wont change to qwerty so the back cover of the phone needs to be facing away from you but not facing down and the screen is facing you and not facing the roof.
its hard to explain but you will get it i think,
if you have any problems give me a shout back ok
please rate this solution, thanks
Jan 23, 2011 | Samsung Cell Phones
When sending a fax, do i face the front side of my document face down or the back side down?
If you are faxing using the feeder , the front page will face up. and if it is on glass/scanner will be faced down.
Thanks for joining us, for more assistance please stay connected with Fixya.
Have a nice day.
Mar 08, 2010 | HP LaserJet 3330 All-In-One Printer
In what direction to you put in the paper when sending a fax? Up or Down?Front or Back? Thanks
Up or down doesn't matter much, as the recipient can always turn the printout around :) But generally putting the documents upside down will make the fax scan the top of the page first.
As far as front/back is concerned, it depends on the construction - if you look at the document feeder you will see a symbol of a sheet with a corner bent, showing the back side. If there are stripes (symbolizing text) on that corner, you must put the document(s) face down; if the stripes are on the rest of "sheet" - put them face up.
In your case most probably it will be face down. You can always check that, and the quality of document scanning (whether the document is not too light for example) by using the "Copy" function of your fax.
Dec 21, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Craftsman chain drive opener won't stay down
Check the down limit:
If the light bulb(s) on your operator are on the front and/or back, the limit adjustment screw is on the left side of the operator (looking from the back of the operator and facing the garage door).. If the lights are on the sides of the operator then the limit adjustment screw is on the left side (looking from the back of the operator and facing the garage door).
Check the up and down force:
On your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Jan 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't stay closed
Jan 03, 2009 | Electrical Supplies
Pioneer DEH-p4600
In the top right corner of the display is a small button that you push in and the face will drop down, this is for putting a cd into the unit and also for taking the face off. Once the face has dropped down you just pull it off. It will come right out. To put it back on again just place it back into the holder with the right side going in first and push it until it clicks into place. It doesn't take a lot of force to put it on or to take it off. If you are still having problems with it you may need to take it in for repair. But usually if the face is having problems with how it is attached, the problem is that the face will not stay on.
Dec 11, 2008 | Car Audio & Video
Idog wont do anything
Turn on underside near front legs. TAIL CONTROLS VOLUME FRONT TO BACK. Push nose and rub face. Connect to MP3 or Ipod switch the short cord end to end and sometimes that makes a difference.
Nov 28, 2008 | Hasbro I-DOG AMP'D
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
