Question about Sony Playstation 3 (PS3) Console
IT COMES ON BUT IT PROJECT OR MAKE ANY SOUND ON TV DONT HAVE HDMI CAPABLE TV
  • 11,896 Answers
Try different channels like AV or INPUT channel. Or hook up to vcr jacks and run vcr to tv.
Posted on Sep 27, 2009
Soundbar connection from Phillips TV to a Samsung HD 550 soundbar
The sound bar only needs sound input from the tv so optical cable connection will work fine. HDMI cable will also work fine. Use the one that you have available.
Mar 18, 2017 | Samsung Televison & Video
If I use a HDMI cable (TV to Sound bar) ,do I need the Sound Bar 'Optical' to TV ?
you shouldn't if both your tv and soundbar are ARC capable. This should be able to send audio from your tv back to the soundbar
Mar 25, 2015 | Audio Players & Recorders
Change sony to hdmi capable
Just connect hdmi,,to ps3 and tv,,power on both and go to hdmi on tv,,should detect it ,,ps3 should pop on screen,,,then when it does choose automatic ,,if it dont hold power to get a few beeps there u go
Nov 29, 2013 | Sony Playstation 3 (PS3) Console
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
I tried connecting HDMI cable from laptop to the TV but sound still comes from the laptop and not coming from the tv. And sometimes even the HDMI is connected between laptop and tv monitor is showing that...
Make sure that the proper drivers are installed on our laptop.
If you plan on using an HDMI connection for both Video and Sound, then with the drivers, you should have an HDMI capable sound driver.
If not, then you won't be able to hear sound from the TV, just from the laptop. Check your system specification to make sure that the system is also capable HiDef sound output.
May 12, 2011 | Televison & Video
When i connected hdmi cable from dell lap to panasonic viera lcd tv only picture is comming no sound comming why plz advice me.
Check your graphics card control panel in the TV out setting and look for a setting to allow sound to be passed trough the HDMI cable.
You could also try changing your default sound output. 1. Right click on the speaker icon in your taskbar 2. Select 'Playback Devices' 3. In the playback tab it will show you devices that are capable of putting out sound from your laptop 4. Look for a device that will output sound from the HDMI port. 5. Click on the device then click the 'set Default' button. Sound should then be going trough the HDMI cable to your TV.
Mar 04, 2011 | Computers & Internet
When hooking up HDMI why can I not get sound I hooked the HDMI from the cable box to the reciver and from the reciver to the TV I assinged the Hdmi and I get picture on the Tv I also can get sound out of...
I have researched on your issue and found that the Receiver is not capable of processing audio from HDMI input. It will bypass the signals from its HDMI input to HDMI output..
The Receiver has 3 HDMI input and one output. Hence you can use this as a HDMI switch to connect three HDMI devices to single HDMI port on the TV.
In order to get the sound from speakers connected to the Receiver, it is required to make alternate digital or analog audio connection.
You can confirm the information from the manual of the Home Theater System. Please refer page # 36 of the Manual to get the information. I have provided a link where you can download the Manual for the HT System:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/580/580HT5100B.PDF
Jan 15, 2011 | Onkyo HT-S5100 Theater System
I have a Motorola VIP1200 set top U-verse converter and a display with SVGA and HDMI. The VIP1200 seems to have a couple of connection options (S-video and a HDMI port). Is connecting them simply a matter...
S-video is only an enhanced picture (video) signal and, must be used with two rca cables: red=left channel sound, white=right channel sound.
HDMI requires an HDMI cable from a HDMI capable (must have an HDMI connector ) cable / satellite receiver to a HDMI TV (also must have an HDMI connector.
Jul 22, 2010 | Televison & Video
I have a Sony STR-DA5200ES amplifier hooked into a sound system and a 52" Samsung LCD TV. The system is set up to operate on HDMI. The problem that has started recently is that the amplifier polls between...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings.
or
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The HDMI on the Sony STR-DA5200ES does not pass the audio. You need to either connect an optical or digital cable from your audio source. If it is a cable box or DVD player there should be audio outputs in addition to HDM.
Hope this will help...
May 25, 2010 | Sony STR-DA5200ES Receiver
Sony Playstation 3 (PS3) Console Logo
16 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
