Question about Radio Communications
Troubleshooting? when the cb is one, there is a lot of static as well as my radio being walked one/over by higher transmits. how do i eliminate the static and how do i raise my transmit to a higher level?
  • 211 Answers
You could peak and tweek it to a legal limit. A local CB Shop should be able to help if they do repairs. Good Luck
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
I have a cobra 29 classic ltd black and chrome bt edition, no matter what antenna i use or how low my swr is i still receive nothing but static all day on all 40 channels. i can transmit just fine but my...
The problem may be in the audio output chip mounted on the chassis, also! there is also a small capacitor located next to the audio chip that has known to be a problem, finally sub the speaker for another, often a source of trouble.
Aug 31, 2012 | Cobra 29 LTD CB Radio
I can,t transmit or receive signal antena is ok
Does radio show receive or transmit on display or meter?
Mic has been tested and or eliminated as the problem?
Apr 26, 2012 | Midland 1001Z 40-Channels Base CB Radio
On my uniden pro 510e I can transmit but I cant receive all I get back is static got any clues?
Which radio are you referring to, the Pro 510e or the Pro 510xl?
In any event, to transmit and receive clearly depends on your antenna, it's location and it's surroundings and HEIGHT.
Radio waves on these radios depend mainly on line of sight and propagation factors, If you have an indoor antenna, that could be the problem, if it's an outdoor fixture, it needs to be in such a position so that the coax cable isn't being interfered with by another electrical fixture, the Height of the antenna, is most important, the higher, the better, taking in all these factors and a bit of try this and see approach should find a solution to your reception/transmition issues. That's part of the fun of setting up a base radio, experimentation, configuration and the results you want will be worth the effort.
I hope this has been helpful for you.
Cheers, Peter
Jan 29, 2012 | Uniden PRO510XL 40-Channels Base CB Radio
Cx80, what does the code "rx" mean on the display
  • TX = Transmit. RX = Receive. Does your needle move when you key the mic? Does it modulate when you talk in the mic? Do you have an inline watt/SWR meter inline? What kind of a set up do you have? Mobile? Base? Get back to me if you want further help.
Regards, Tony
Oct 18, 2011 | Cobra 29 LTD CB Radio
There is no output when transmitting the radio says rf power output fail on the radio check
You can try to replace the final transistor and see if that helps. Do you have receive? Plug an external speaker into the PA and switch the CB to PA and key down. If you hear yourself that eliminates the voice chip. Always make sure you check your SWR and maintain below 1:1.5 no higher than 2. Any further questions of comments let me know.
Mar 01, 2011 | Cobra Radio Communications
I have a cobra 29 ltd chrome and it making a lot of static noise while driving or idling. it transmits and recieves fine though
Hi, my name is John. Welcome to FixYa. Try running your power strait from the battery, that will bypass a lot of your noise. RED (+) ground (-) . Thanks for choosing FixYa....John
Nov 30, 2010 | Cobra 29 LTD CB Radio
Whats the best height for a base antenna
best height is as high as possible.
height = might
Dec 13, 2009 | Raytheon VHF 53 CB Radio
Static noise in my cb radio
A lot of times the "static" Is actually a loos connection in the microphone or a dirty micke gain control. Radio shack sells a cheap tuner cleaner if you know how to take the covers of and find the mic gain control, spray it in the little slot in the control( be generous) move the knob back anf forth several times. Also if you have another mike wired for cobra, try it and see if it helps. Those two solutions fix 98 percent of the problems. If it doesn't, please let me know. I am very good with cobra radioes and am sure we can solve this problem.
Good Luck. If this so;ution helps, please rate me.
Jan 30, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
I have no reciving in a cobra 29 ltd chrome
Bad switch. It's that simple. The factory switches are crimp together junk. You may be able to use a pair of needle nosed pliers to softly squeeze the case of the switch together to correct the poor contact in side of the switch, but, if it gets a lot of use you may need to replace it altogether. Or try adjusting
Apr 29, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
169 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
