Question about Insignia D400a PC Desktop
My internal card reader does not work and some of my usb ports dont work
  • 11,896 Answers
Go to control panel, performance & maintenance. Then go to device manager and find your devices. Make sure they are enabled and make sure to update all drivers.
Posted on Sep 27, 2009
(dual boot system)will not read a card reader in vista 32bit, but works fine in windows 7 64bit. Loaded drivers in Vista
Try driver download from her http://www.startech.com/Cards-Adapters/USB-3.0/Cards/2-Port-PCI-SuperSpeed-USB-3-Adapter-Card-with-SATA-Power~PCIUSB3S22
Although I dont understand your statement " will not read a card reader" since you state a problem with the Syba Infozone cable.
Is the problen your USB 3 port or the Syba cable.
Mar 29, 2014 | BestPriceCables Syba InfoZone SuperSpeed...
I have a PNY usb 2.0 combo. The usb ports work fine and read external drives etc. The SD readers quit working. The SD cards read fine on the internal mounted reader. My PC recognizes the drives, and t
I bought a deer cam (trail camera) at Walmart and a PNY card with PNY Multi-Slot USB & Flash Card Reader P-UBSDRDR21K-RF. I can't make them all work for me. PNY card reader has no instructions on the package neither on their website and their support is a joke. When I plug in this multi-slot card reader into my PC (I tried two different PCs) something isn't right. I get no results, just empty folders. The card is new and has data on it. Both products come from PNY, both were purchased at Walmart and both are going back to Walmart for a full refund and I will never buy a PNY product ever again.
Feb 14, 2013 | PNY Memory Card Reader and USB Hub Combo
I would like to install a internal card reader with a usb port.
Those wires go into an internal USB extension connector - which your motherboard doesn't have. Get a PCI USB card and connect them to it - this way you will also get USB2.
Mar 10, 2010 | Chaintech CT-6OJV2 Motherboard
Gateway GT5228 - USB Ports & All-In-One Card Reader don't work...
what service pack froom MS have you downloaded and installed? Sounds like the SM BUS DRIVER ARE MISSING. Install SP3 AND LET ME KNOW.
Feb 16, 2010 | Gateway GT5228 PC Desktop
3.5'' internal memory card reader/writer installation problem
Your reader/writer is set up for use on 2 USB ports (hence the 9 pin connector), one port for the reader and one for the externak USB port. This has nothing to do with the port version. The long and short of it is you need a card with a matching internal header. NEVER break off a pin! Some of these headers have reversed connectons so you probably broke of one of the data pins and runed that header's ability. Typically the readers like you have come with several cables, so that they can match the headers you have available. Older motherboards and add on USB cards did not use standardized header configurations aas you seem to have found out. Your best bet at this point is contact the manufacturer of the reader and find out what brand of add on USB cards they recommend and go with that. AND AGAIN NEVER REMOVE ANY PINS FROM A HEADER !!!
Feb 11, 2010 | Computers & Internet
How to install a sd card reader on a Dell Dimension 8200 PC Desktop? no 4 pin usb on motherboard?
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Jan 23, 2010 | Dell Dimension 8200 PC Desktop
My remote don,t work on my acer 1800 , and the sd card reader don,t read. I did replace the battery in the remote,I have XP MEDIA CENTRE installed on the laptop.
laptops don't have remotes, and for the sd card reader unplug it from the laptop and try it in a different usb port if that does not work then i dont know. ive got an sd card reader and my laptop didn't find mine until i tried it in a different usb port
Oct 27, 2009 | Acer Aspire 1800 Notebook
My USB cord will no longer plug into my camera.
Buy a card reader and stop using the USB port. Card readers are much faster to download pictures into your computer. This will only work with a memory card in the camera and not internal memory. All these items today are vey inexpensive to purchase.
Jul 01, 2009 | Kodak Easyshare M893 Digital Camera
Internal USB connector
You did not have to unplug the onboard USB ports.
Your OS should see the card reader and set it up, unless you are using Win98 or WinME. I would plug the onboard USB ports, then restart with the new internal card installed.
Sep 26, 2008 | Dell Dimension 4600 PC Desktop
Imstalling internal card reader
Well, installing an internal card reader without a spot on the motherboard, is a little hard to do. I would suggest buying an external card reader. They are a little cheaper, and a lot easier to setup and use, since they just connect to a USB port which all computers have.
Feb 23, 2008 | Dell Dimension 3100 PC Desktop
Insignia D400a PC Desktop Logo
136 people viewed this question
Top Insignia Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
