I think the cold-water solenoid went bad on my washer - plenty of hot water flow, but cold only trickles into the washer. The rest of the house is fine for water pressure.
  • 1,531 Answers
Yes the most likely problem is your water valve hasgone bad.but check the hose connection and see if there is any sediment built up in there. if not replace the water valve
Posted on Sep 27, 2009
Testimonial: "Thanks for confirming my suspicions! I am seeking a new valve for my washer online now."
Water does not get hot on a hot wash
Shut off the water. Disconnect & check the BOTH water supply hoses at the MACHINE to check for obstructions / kinks / etc: Check for and clean any strainer / filter on the hoses and inlet to the washer. Direct the hoses into a tub or other container and turn water ON. make sure you have water flow from BOTH hoses and that one is HOT and the other is COLD. If OK, reconnect to machine. Turn water back ON. Choose a WARM wash.
If you get COLD only, you probably have a bad HOT solenoid - if HOT only you have a bad COLD solenoid. Be sure by:
Shut water off and swap hose connections (hot to cold & cold to hot) and try again.
If you get COLD only, you probably have a bad COLD solenoid - if HOT only you have a bad HOT solenoid. If you get HOT only, you probably have a bad COLD faucet / hose - if HOT only you have a bad COLD faucet / hose.
Replace the bad solenoid as needed. Good luck!
Sep 28, 2015 | Hotpoint WMA48 Front Load Washer
My hot water flows freely into the tub but my cold water only trickles in, I have checked the cold valve and the hose and found no obstruction. I have also checked the connection to the unit and the
You already checked the hoses and valve so if you just have a trickle, the the solenoid on the cold side is failing. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Only a trickle of cold water coming into washing machine
If there is no other restriction, the water should flow freely from the hose into a bucket as a test. If good, then it must be a restriction in the solenoid valve. Some can be disassembled and cleaned but the valve assembly is not expensive to replace.
Nov 23, 2009 | Kenmore Washing Machines
Kenmore HD Series 80 - hot water trickles in.
Pull the two screws at the bottom corners of the control panel. Pivot the panel up. Lever the two metal keepers underneath forward and up to remove them. Tilt the housing forward and pull it toward you to remove it. Make sure you unhook the lid switch wiring plug before you remove the housing.
Water inlet valve should all be one piece for hot and cold.
Nov 15, 2009 | Kenmore 26882 Top Load Washer
Rinse cycle water flows out to a trickle- regular wash cycle flows normal- water valve?
Flows out where , drain or into machine ? If into machine , Most washers have a cold rinse into machine . If your using hot fill and you get a trickle , then problem is a clogged screen at the valve or a bad water valve .
Jul 06, 2009 | Washing Machines
Getting only cold water to my washer; hot water is not there
Hot water solenoid valve on washer not working. Test resistance across connectors. No resistance equals bad solenoid. Their not expensive and easy to install.
Mar 29, 2009 | Kenmore 20722
Washer will not fill up with hot or warm settings, only cold.
kenmore washer hot or cold fills ok but will not fill with warm but only cold water
Mar 15, 2009 | Kenmore Washing Machines
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Top loading washer
well first check for kinks in the cold water hose and also see if there is anything blocking the water flow from the hose.
If all looks find, then try replacing the solenoid valve for the cold water intake
Please let me know of anything you find or have questions on
Sep 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
