Question about Carrier Heating & Cooling
No cool air comes out of our unit even though it's running. System is about 2 years old-a little less. Filter regularly changed. The pan underneath is also full of water.
    Problem Solver:
  • 14 Answers
Are the unit is upflow (on the closed) or horizontal (most like it on the attic)
if is horizontal and the drain pan is full seems the main drain is clogged can you blow air thru drain?  make sure you dont have a flow swith on the drain pan that prevent the condenser to come on
Posted on Sep 28, 2009
My 9 year old 17,500 BTU wall mounted window Unit is freezing over with little air coming out. New filter & clean coils still have same problem.
Sounds as though the indoor fan is about to give up the ghost.. 2 choices . 1 start looking for a newer more effecent unit. 2 replace the fan motor.. sorry but it does not sound good..Wiat I just thought It just might have a run capasitor ?? Not sure.. But it could be going bad as well .. Justa thought on that one. either way you can call a tech or buy a new unit.
Aug 08, 2011 | Friedrich Heating & Cooling
Unit won't cool. Unit is set on is on cool, but warm air comes out. Is there a reset button on the unit ? Unit is 21 1/2 years old.
Some of those old Mach 3's have a manual reset pressure switch, but you will have to take the cover off to find it. Most manual resets have a red button to push to reset. The unit may be low on refrigerant or the condenser coil stopped up with dirt.
May 13, 2011 | Coleman Mach III Air Conditioner
I have a LG Artcool LAN121HNP the unit will only ciculate air (not cool) it is only 2 years old. I have had an HVAC guy look at it, he says the compressor is fine. We have put a new board in the outside...
Make sure none of the thermostat wires from the inside unit to the outside unit have come loose or have be cut by a weed eater or such. These units are a little more complex than your average heat pump.
Aug 24, 2010 | LG Art Cool LA181CNW Split System Air...
I have a 7 year old 2 1/2 ton rheem ac 10 seer that worked great until yesterday and it was not cooling when I came home and will not come on. ?
start with the basics. reset the breaker. Even though it may not look tripped, I've seen breakers trip and the lever/handle not move. Can fool you. Look inside the disconnect by the unit to see if there are fuses. Check them as one or both may have blown.
Start there
Jun 10, 2010 | Heating & Cooling
Air not cold enough to cool house
Make sure the outside fan is running. Also check the high side pressure, I assume the 70# is the low side pressure, so you can tell what the compressor is doing. If the fan and compressor are both working, make sure there is good airflow through outdoor coil and check that it is clean. Let me know what you find.
May 17, 2010 | Goodman CLJ24AR32 Air Conditioner
AC shutting down, not cooling
your landlord needs a service tech !sounds like you have a few issues.possibilities include control issue,plugged evap coil,plugged blower wheel,possible freon issue.This one's a little too big to handle here.
Jul 26, 2008 | Ruud UBHC Air Conditioner
Cools for a while ... keeps running but stops cooling.
If the refrigerant has been accurately charged and diagnosed, I would look for an air restriction. Check your filter first of all. It sounds like it may still be trying to freeze up. Make sure all the vents are at least a little open and the return grill is not blocked. In the Rocky mountain region we like to see around 44- 50 deg. at the vents. 65 would tell us that everything is not ok.
Jun 16, 2008 | Carrier 38CKC060 Air Conditioner
LG Dehumidifier Not Working
the freon has leaked out, must be replaced.
Jun 05, 2007 | LG LD65EL Dehumidifier
Heating & Cooling Logo
76 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
