Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I need cable to go from my 40 to my TV can you
I need cable to go from my nikon 40 to my TV can you help?
    Guru:
  • 441 Answers
Your camera has an AV outlet just above the usb outlet. If you did not receive the AV cable with your camera I'm sure it wont be hard to find. Check your local camera or electronics store.
Cheers
Posted on Sep 27, 2009
Can I get user manual for Nikon MB-40 multi-power battery pack for F6 body?
I think the extent of the instructions is on the Nikon USA web site. Here it is
"The Nikon MB-40 Multi-Power Battery Pack accommodates eight AA (alkaline, lithium, or Ni-MH) batteries, or the Nikon EN-EL4 Rechargeable Li-ion Battery. The MS-40 Battery Holder comes with the MB-40. With the MB-40 attached, film can be advanced as fast as 8 fps.
When using the EN-EL4 battery, the Battery-Chamber Cover BL-3 must be used.
The MB-40 is also a vertical grip, and features a vertical grip shutter release, an AF start button, and Multi-selector and Command Dials for more comfortable and responsive shooting."
Oct 15, 2014 | Nikon Used MB-40 Multi-Power Battery Pack...
Can i connect the Nikon L20 to TV?? I trired using the A/V cable but i got a blank screen....i was not able to see a damn thing on the TV screen..
FIRST MAKE SURE THE CAMRAS OFF. SWITCH YOUR TV TO THE VIDEO CHANNEL. PLUG THE A/V CABLE INTO BOTH THE TV AND CAMERA. THEN USE THE PLAY BACK BUTTON TO TURN THE CAMERA ON INSTEAD OF THE ON/OFF BUTTON.
HOPE THIS HELPS . =]
Jan 12, 2010 | Nikon COOLPIX L20 Digital Camera
Tv guide freezes then tv switches off
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Dec 30, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Nov 30, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Nikon d40x camera not working
The camera has a bad shutter or a bad sequence plate motor .
If you need help further contact
Berrie Smith Camera Repair
Apr 04, 2009 | Nikon D40x Digital Camera
Sanyo TV DP42647 No picture or sound, remote does nothing
Mar 17, 2009 | Sanyo 42 in. LCD TV
How to connect IBM T61 to my Samsung LCD TV 40'' 3xHDMI
If you have an s-video port you will need to buy s-video cables and a separate audio cable for sound. With HDMI you will only need 1 cable for both video and sound. Just connect your s-video cable to your s-video output ( your laptops quick reference manual should show you where your s-video jack is at ) and the other end to the back of your LCD tv video input ( consult your lcd tv manual )
Jan 02, 2009 | IBM Lenovo ThinkPad® T61 PC Notebook
Nikon-d40 (shutter relese problum)
Can you explain more please ?
The Nikon D40 does not have shutter release or as known cable release, but does have a wireless remote control release.
If the shutter is not working properly....
Remove the battery and reinsert.
Remove the memory card and try again
Check the lens is correctly fitted.
Is the lens a compatible fit
Dec 14, 2008 | Panasonic NV-MD9000EN Mini DV Digital...
Viewing pictures on tv
This suggests a possible fault with the TV A/V circuit. You can check this of course by trying it out on another TV
Aug 19, 2007 | Nikon Coolpix 5600 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
