Question about Samsung L100 Digital Camera
My camera wont turn on. Period. Ive charged it and it still wont turn on. It also started to get hot which has never happened before.
My camera wont tur onwhat can i do?
Hello....This will be short and sweet....Check to see if the battery is charged and installed properly...I had this troblem with My FujiFilm camera...In my camera...you can install the battery backwards and it will not work...so check the battery charge and installation first....Let me know what happens......I hope this was helpful......PEACE......
Mar 08, 2012 | Sony Cyber-Shot DSC-P150 Digital Camera
My camera, a nikon d70s, wont turn on and work. ive taken the battery out and out it back in, still wont work. i then tried 2 charge the battery but still wont work. i then tried to re-set it but it still...
If the camera does respond when you hold down the shutter release, then the internal clock battery may have drained. As the manual says on page 17, charge your main battery, put it in the camera, and leave it be for up to three days.
Feb 15, 2011 | Nikon D70s Digital Camera
The battery wont charge and it is only the second
Try turning the battery over in the charger. It sounds like the wrong side is up.
Jun 03, 2010 | Nikon COOLPIX S570 Digital Camera
It won't turn on! I charge it, and the camera is no more than a year old, and yet it wont turn on. However, when it's on it's base, it can connect to my computer and turn on fine! Is it the battery?! Why...
Mine won't turn on...unless I hit the red button, then the menu button, then repeat...the red, then the menu. When the menu comes up, it wants to reset the date/time etc. I just ignore that and hit the menu button once more and it's ready to shoot. Pain in the you know what.
No more Casio cameras.
Jun 26, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
Canon Poershot sd300 digital elph. It just wont turn on period.
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Apr 04, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
D900 - Wont turn on !
CHANGE THE CHARGE CONTROL IC,LOCATED BY THE BTEMP BATERY SAME LIKE D500
Sep 15, 2007 | Samsung SGH-D900 Cellular Phone
Samsung L100 Digital Camera Logo
74 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
