I need the the four digit code for a one for all so easy urc-3030b04 my tv is a magnavox
  • 54 Answers
Should be one of these :- 0036 0179 0037
Posted on Sep 27, 2009
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
NEED CODE FOR GE URC FOR MAGNAVOX SDTV
These are the codes most likely to work for a GE URC and a Magnavox SDTV.
Your remote will only use 3-digit codes or 4-digit codes, and not both.
004, 008, 009, 062, 068, 069, 074, 075, 076, 077, 089, 133, 141, 163, 165, 226, 288, 456
0062, 0004, 0009, 0456, 0183, 0226, 0288, 0008, 0068, 0075, 0141
1. Manually turn on the device TV.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the TV. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off. If it turns off after 004, it uses 3-digit codes only. If not, enter a 1 for code 0041, which will not work, and go to step 2 for 4-digit codes.
5. Aim the remote at the TV and press the POWER button. If your device does not turn off, go to step 2 and try the next code.
(6. If none of the codes work, please reply.)
Jun 22, 2014 | Televison & Video
I need the codes for One For All Big Easy URC-3300B07, to program Samsung Slim TV
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy. Surf the site patiently.
Mar 23, 2013 | One For All URC-4330 Remote Control
I need codes for big easy oneforall remote urc-4330b04. i have a magnavox tv
Hello
Codes for Magnavox TV with One for all urc-4330 are:
0054, 0030, 0179, 1254
OK.
May 15, 2011 | Televison & Video
I need the the four digit code for a one for all so easy urc-3030b04 my tv is a phillips
Hello
Codes for Philips TV with URC 3030 universal remote control are:-
1223, 1311
Turn on your TV, VCR or Cable Box, depending on the
device you are programming.
Press TV* and release. Press and hold SETUP
until the One For All® Easy 3 Device's red
light blinks twice. Release SETUP
Note: When setting up your VCR and/or Cable Box,
substitute the appropriate device key (VCR or CBL
Enter the
first four-digit
code you wrote
down for the
device you are
setting up. (See
"Looking Up Your
Electronic Device
Code".) If you put
in the code
correctly, the red
light will blink
twice
OK.
Dec 16, 2010 | Televison & Video
Need a tv code for Magnavox. Using
Code for Magnavox TV are
Thanx
Aug 01, 2010 | One For All URC-3300 Remote Control
Need code to reprogram oneforall remote for
To control a Magnavox TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0054, 0706, 0030, 1454, 1254
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
Nov 27, 2009 | One For All URC-3021 Remote Control
Need code for magnavox television with cable (remote control urc-3220)
URC 3220 One for All Big Easy Remote Control
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Magnavox TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Oct 22, 2009 | Philips TV Tuner Video Capture PCI Card -...
Need RCA univeral remote control code for Magnavox 27MS343S
Push in and hold code search button until it stays lit, then pushed the TV button, it flashes quickly. Then hit the number zero once, then hit channel up button until tv finally changes channel. Hit the mute button once to get it to store the code.
Feb 20, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
Electro Med Services...
