Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Sreekidu my tv shots of and on and sometimes it will shot of 3 or 4 times quickly in a row whats my problem
  • SuziM Mar 03, 2008
    The TV turns off and then back within a minute. Sometimes does it a few times and hour and then sometimes more frequently. Any suggestions??
    President:
  • 4,402 Answers
Sounds like a common problem where the Horizontal Output Transistor shorts due to heat, loading by a partially shorted flyback or yoke or old dried heat sinksreekidu - 2.gif compound.
or could be convergance amp ic's
Posted on Dec 18, 2007
My bike juststopped-as if out of fuel.good spark,fuel getting through,good compression.any ideas please?
Engines have certain things to do in order to run. They need fuel, compression, spark and with correct ignition and valve timing. Sometimes when you think your getting fuel your not. A quick way to see if you are lacking fuel to the cylinder is a shot of starting fluid in the air cleaner but just a quick shot. Give it a kick and see if it starts and runs for a short time untill the fluid is consumed. Is the fuel old? Did this bike just come out of storage for the winter? Did someone or something build a nest in the exhaust system?
Apr 19, 2011 | 2002 Aprilia RX 125
My camera takes multiple shots, three in a row, for one click. How can I get camera to take one shot per click?
There is a setting for this. Depending on the camera the setting is in the Menu.
Usually you use the single shot S setting but for sports events 3 shots can be taken after each other.
Please rate Fixya answers
Mar 12, 2011 | Sony Cameras
Just bought Cabela's Dangerous hunt 2011 and I'm having trouble syncing gun with console, any advice? Thanks
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook. http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
Activision HuntsCablela's Dangerous Hunts 2011: How-to-Guide for the Top Shot Elite
You have two options when playing Cabela's Dangerous Hunts 2011 with your Top Shot Elite. You can either play with the default setting, or you can calibrate the gun to your television set.
Option 1: Default Setting - Sensor Bar Position
The default setting will work fine for most people. However, you will need to ensure that the sensor bar position is set up correctly within the game. If it isn't, you may have issues with aiming and lining up the reticle that appears on the screen.
How to Setup the Sensor Bar Position:
1. From the main menu, select "options"
2. Select "Controls"
3. Make sure that the "Use Calibration" option says "No".
4. Select the Sensor Bar position that matches your setup. Top means that you have the Sensor Bar above your TV, and Down means that you have the sensor bar below your TV.
Option 2: Calibrating your Top Shot Elite
Calibrating the Top Shot Elite is not necessary to play the game, but it can help improve the aiming experience if done correctly. It should be noted, however, that not all homes are ideal for calibration. You should only calibrate if you can stand comfortably 6-8 feet in front of your television.
How to Calibrate:
• From the main menu, select "Options"
• Select "Controls"
• Select "Yes" in the "Use Calibration Option."
• On the calibration screen, you'll see a target in the upper left hand corner of the screen.
• Stand at least 6 feet away, aim through the scope and line up your crosshairs over the target. Pull the trigger to continue.
IMPORTANT: A message will say "Cannot detect gun position" if it cannot read your Top Shot Elite. Usually this means that you're standing too close to the TV. Try backing away from it. If you're still unable to line up the scope with the target, read through the tips section below to ensure proper setup.
• Next, you will see a target on the lower right of the screen. Aim through the scope and pull the trigger to continue.
• Now check the calibration. Look at the screen through the scope. When you move the gun around the screen, the on-screen reticule should stay within view of the scope. As long as the reticle is visible, your calibration should be ok. If, however, you can't see the reticle at all times or you're simply not happy with the results, select the calibrate option to retry.
• Once you're happy with the setting, you'll need to save them. Exit the calibration screen and select "Yes" (you would like to save your settings).
Note: Moving your position within your room may throw off the calibration. If you decide to change positions, we recommend recalibrating for the best results.
Additional Tips and Tricks to Having a Good Experience with Your Top Shot Elite.
1. Room Setup
• Make sure your room is comfortably lit - not too bright. Your TOP SHOT Elite has a built-in infrared camera and will have less trouble seeing the infrared lights from your sensor bar if you turn down some of your lights a bit.
• Make sure you've removed extra lights near or around your television. The TOP SHOT Elite includes a small camera that looks for infrared light. If you've got little lights or even candles around your television, your camera might have a hard time seeing the sensor bar.
• Turn off other gaming consoles. Other gaming consoles might interfere with your TOP SHOT Elite. For example, if you're trying to use your Xbox 360 TOP SHOT and you have your Wii turned on, the sensor bar from your Wii could interfere with the wireless sensor bar for your TOP SHOT Elite.
• Give yourself plenty of room. The TOP SHOT Elite works best if you're standing about 6 to 8 feet from your television. In addition, you want to make sure you don't have any breakable objects near you when you're playing with the TOP SHOT Elite. This includes vases, lamps, other people, and anything else you wouldn't want to accidently hit with your TOP SHOT Elite.
2. Sensor Bar Setup
• Set your sensor bar at a comfortable height. Your TOP SHOT Elite needs to see the sensor bar at all times. Generally speaking, you want to set your sensor bar above or below your television so that it is as close to eye level as possible.
• Make sure your sensor bar is on. Please note that the wireless sensor bars that come with your TOP SHOT Elite don't stay on all the time. To save on battery life, the sensor bars have a built in timer that shuts off automatically. You can set your timer by adjusting the small switch in the back of the sensor to 1, 2, or 3 hours. When your sensor bar is on, you'll see a little red light in the front.
• Why isn't there a Sensor Bar Position option when I calibrate? When you calibrate the Top Shot Elite, the game automatically figures out where your Sensor Bar is, so you don't need to manually set it up.
3. The TOP SHOT Peripheral
• Turn it on and sync it up! Your TOP SHOT Elite peripheral is a wireless controller that needs to be synced to your console. If you need help syncing your TOP SHOT Elite, please refer to the following guide to help you out: Customer Service FAQ
• The forward control stick. Sometimes you need just a little extra help. Located on the front left of your TOP SHOT Elite is a second control stick that you can use to help you quickly turn while playing Dangerous Hunts 2011.
Jan 08, 2011 | Activision Cabela's Dangerous Hunts 2011...
I just purchased Cabelas dangerous hunts 2001 for my xbox 360 console..... I cannot get the gun to sync with my xbox....Please help!
See the Top Shot Elite Set Up Guide on the Discussions Tab at Facebook.com/ActivisionHunts or contact Activision Assist on Facebook.http://www.facebook.com/topic.php?uid=133041143393695&topic=331
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
How do I get started using the gun?
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
Jan 03, 2011 | Activision Cabela's Dangerous Hunts 2011...
Sensor bar doesn't stay on unless the button is held in.
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
Dec 31, 2010 | Activision Cabela's Dangerous Hunts 2011...
Problem with the Activision Cabela's Dangerous Hunts 2011 with gun for Xbox 360. When aiming for calibration it wont turn red unless you point gun directly at sensor bar
The same is below.
How to Calibrate:
• Select "Controls"
1. Room Setup
2. Sensor Bar Setup
My memory card is unavailable on my sony ericsson cyber shot phone 5.0 megapixel, what do I do? It was fine with no problems but now it's just died. Can I fix it? Help.
switch off ur phone , remove ur memory card , wipe the golden coloured connecters with a damp cloth , insert it and remove it 2-3 times in quick succession , insert it start your phone and it should work fine , just try this it really works.
Dec 03, 2010 | Sony Ericsson Cyber-shot C902 Cellular...
Problems with the shutter of a FM
Those camera are repairable & still sought after. If you're interested in continuing to use a quality camera, I don't think you'll find a better camera for the cost of the repair. Take a look in the back of Popular Photography there's repair shops listed that do great work & better than most prices. Think its Modern Camera, or something like that. Be sure to get an estimate. As for suggestions on where to start? If you mean repairing the camera, this will be fun. To start you will need some very small screwdrivers, paperclip & perhaps a small hammer. I'm really good at taking them apart, but I've never put one back together.
May 15, 2007 | Nikon FM2N 35mm SLR Camera
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
