Question about Brother PT-65 Personal P-Touch Electronic Labeling System Printer
I can't get it to work. I type in a line and print and I just get vertical lines instead of the words I typed. What am I missing?
checkitright
  • 1362 Answers
SOURCE: Blank vertical line on pages
open side door, should be a black assembly there with two wires, is it clean? is there any toner or hair on the wires?
Posted on Nov 14, 2007
  • 8 Answers
SOURCE: LINES
open the printer door, press the clear/back button LCD should read reset counter, answwer 1 for yes, that should take care of problem
Posted on Feb 15, 2008
SOURCE: Vertical black line on all print outs
1) Check the cartridge. Look at the egg color drum and see if there is any built up toner. If there is then wipe off with soft cloth and reinstall.
2) Does this happen when coping from the flat bed and the doc feeder at the top?
If it it's only from the top then there is a glass lense that might have white out on it.
This is common when using white out and not letting it dry long enough.
To get to the lense it my be tricky but if the top of the feeder open a little from the top pop it open and
the glass is a thin 1/4 strip. Wipe it clean then try again. Hope this helps. Boats
Posted on Oct 07, 2008
  • 744 Answers
SOURCE: When printing from word 2007 on vista bold type is gibberish
Try re-installing the printer driver(s) first. If no luck, then un-install the printer completely, reinstall and try again. You may also have an issue with an incompatible driver with Office 2007. After reinstalling the drivers, try to print a test page and see what happens.
Posted on Apr 17, 2009
  • 555 Answers
SOURCE: Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Posted on Sep 17, 2009
It sometimes types the letter s,t,and sometimes it replaces them with two vertical lines.
Most likely one or more of the spokes is bent on the print wheel. Remove the wheel and turn it by hand you can usually straighten them. The vertical lines are from the face of the hammer when it misses the letter.
DickyO
Jun 25, 2015 | IBM Wheelwriter 3 Electric Typewriter Type...
Why is my printer missing lines
I think you need to change your ink cartridge.
Jan 24, 2015 | Brother MFC Office Equipment & Supplies
How do I fix canon mx310 which prints with lines
please check doc. page setup, may be outline or outside margin resulting not space.
Apr 15, 2010 | Canon PIXMA MX310 All-In-One Printer
Photosmart D7460 will not print envelopes from Printshop 23
u should go to print setup in ur program then go to paper type which u want to use it then select "Envelop" instead of "A4"
Jun 14, 2009 | HP Photosmart D7460 Printer
I have a X7170 it has recently began printing with vertical blank areas on the printed copy. In other words up and down on the page there missing copy. I have changed ink cartridges and this does not help....
Uneven vertical lines can be adjusted by
performing the printhead alignment adjustments.
The user is directed through the Lexmark Solution
Center to perform the printhead alignment
adjustments when replacing a printhead cartridge.
The alignment can also be performed from the
control panel by selecting the Maintenance Option,
then Align Cartridges.
Feb 01, 2009 | Lexmark X7170 All-In-One InkJet Printer
Vertical print residue left about half inch past the longest line printed
inside the front cover, under where the head parks, you will find a vertical wiper. Clean it.
Power off. open front door. push down cutter (blue) and slide head to the left. To the right of the cleaning pad is the wiper. clean with rubbing alcohol on both sides.
Run a normal cleaning.
All set
NOTE: you do not need to put the head back in place. when you power on it will automaticly park itself
Nov 06, 2008 | Epson Stylus Pro 9800 InkJet Printer
Swintec 7040
If what you are saying is that you get 2 vertical lines instead of a letter start with a new printwheel, what you are seeing is the hammer face when it misses the printwheel.
DicktO
Aug 30, 2008 | Swintec 7040 Typewriter
Nov 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother PT-65 Personal P-Touch Electronic Labeling System Printer Logo
14 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
