Question about HP Office Equipment & Supplies
The middle light is blinking when I turn the printer on. I can not stop it and it will not print. What should I do?
    Scholar:
  • 67 Answers
Remove all the cartridges from the printer, then perform the below steps
  1. Disconnect the power cord from the back of the product.
  2. Disconnect the power cord from the electrical outlet, and then wait 60 seconds.
  3. Connect the power cord to the electrical outlet.
  4. Connect the power cord to the back of the product.
  5. Press the Power button to turn on the product.Then insert the cartridges one by one to the printer while it is on and check for any error, the issue would be with cartridges and can be isolated.
Posted on Sep 27, 2009
Bogdan
  • 198 Answers
SOURCE: Lemark Z52 Inkjet
Hello, First of all, let's start with some simple questions. 1 Was the cartridge ever refilled or is it in the original state? 2 How exactly did this occured? I'm asking this because most printers have a limited space inside them for the cartridge to move around when printing. If they don't fit exactly as they should, they will most likely hit something in their movement when printing. If your cartridge was refilled maybe the person who did that didn't attached the cartridge top part properly and now it moved out of position and hits the inner top of the cartridge housing. Please provide me first with these informations so I can better assist you.
Posted on Sep 09, 2007
tom19511
  • 1601 Answers
SOURCE: Printing problem
Blinking lights:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00859572&lc=en&cc=us&dlc=en&product=1100995&rule=44647&lang=en
Offline:
  1. Open the Printers folder.
  2. Right-click the icon of the printer in use, and then click Open .
  3. Click Printer on the menu, and then ensure that there are no checkmarks next to Pause Printing or Use Printer Offline . If a checkmark is present on either, click the menu option to remove it. If the menu shows Use Printer Online , click that option.
  4. If neither Pause Printing nor Use Printer Offline are checked, press Esc to leave the menu without making changes.
Posted on Nov 30, 2007
StephJohn
  • 10 Answers
SOURCE: printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Posted on Mar 18, 2009
micromend
  • 748 Answers
SOURCE: My hp 1012 printer stopped printing.
You've probably slipped a gear or something is lodged inside. Unplug all the cables, take out the paper, lift it up, turn it upside down and shake it. This is good for getting out staples and paper clips. Hopefully no gears are damaged. If problem continues, probably a gear is slipped. If the shaking doesn't dislodge anything then either call a technician or just replace it.
Posted on Apr 03, 2009
  • 16 Answers
SOURCE: print job stops in the middle of a print job
first if its happening from few days than go for system restore - start - all programs - accessories - system tools - system restore.. select that date on which it worked fine.. or else add printer and install deskjet 990c and than try
Posted on Oct 14, 2009
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
We are in the middle of printing our Tax Return and an orange light keeps blinking on the top of the printer - and it has stopped printing.
Hi and thank you for using fixya:
On this specific printer model this light means that your paper has jammed, you need paper, or your ink is low. Please re-start your computer and printer and try again. If problem persists check ink levels on the printer settings (computer)
Good luck
Apr 13, 2010 | HP DeskJet 932c InkJet Printer
HP DeskJet 812C Hardware Problem! with Printer cartridge carriage. Printer Cartridge retracted into right side of case will not come out. There is No paper jam in machine to prevent it from doing so. ...
Disconnect the "data" cable (parallel or USB).
Disconnect the "power" cable.
Reconnect the "power" cable.
Turn the printer on.
Lift the printer's lid -- the print-carriage should slide the printer-heads to the "middle" position.
If all else fails, take the printer to a qualified technician, for more trouble-shooting.
Feb 02, 2010 | HP DeskJet 812c InkJet Printer
Right in the middle of printing it will stop, and the power light blinks. This problem is intermittant and frustrating! What does this mean? Thanks.
Its caused due to a Paper Jam , What you can do is turn upside down the printer and shake to see if any paper has got stuck. then replug and check for a test page.
Jan 27, 2010 | Matrix Star SP200 Receipt Printer
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Failure to print
Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
J
Aug 29, 2008 | HP DeskJet 932c InkJet Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
Uncompleted printing job
My Lexmark Z715 printer has always worked fine until this morning. I turned it on and the light blinked so I turned it off and then on again and the cartridge slamed one side of the pinter and then slamed the other side. I tried it several times and always the same. It would not stop in the middle so I could check it out. Does it need replacing?
Apr 18, 2008 | Lexmark Z715 InkJet Printer
HP 952c
hi!
Try to cancel your document in the printers menu even if you restart the pc or the printers memory stores the previous command.
1.The idea is that printers has its own memory unless you cancel the document that you print.
e-mail me at wendel_tenebroso@yahoo.com if the problem persist
Apr 08, 2008 | HP DeskJet 952c InkJet Printer
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
