Question about Denon AVR-3805 Receiver
No DVD sound from the AVR-3805 through the DVD-2910/955 Coaxial digital output attached to digital in Coaaxil-1. Video is good. Sound is availble from the 2-Ch Audio out. "Digital In" for the "DVD" is set to "COAX1". Any suggestions?
  • 448 Answers
This is the normal operation of the receiver while playing a DVD disc. In this case, try changing the sound field on the receiver to get surround sound from the receiver while playing a DVD disc.
You may set the sound field to Pro Logic or Pro Logic 2 or any A.F.D sound field.
good luck!!!!!!!!!!!!!
Posted on Sep 28, 2009
Denon 3802 connected to blu ray player but playi g dvds, how do i get dd 5.1?
You cannot get 5.1 sound from DVDs that are not encoded with 5.1 sound. They may be stereo, which will only send sound to the main front L/R speakers.
Nov 23, 2013 | Denon AVR-3802 Receiver
Does the Harmon kardan avr25 have an hdmi output
Nope. You get one component OUTPUT (monitor) and two component INPUTS (Vid 2/DVD) but no HDMI video output.
If you can input and switch HDMI video directly at your display from your cable/SAT etc. you should be fine, just run all the audio through the AVR-25 through the coaxial/optical digital inputs, L/R analog RCA or the 5.1 direct inputs.
Feb 13, 2013 | Harman Kardon AVR 25 MKII
How do I set my receiver to read TV/CBL Dolby Digital. It is a AVR 789
The Dolby digital signal is outputted only through the Optical or Coaxial socket of the CBL box. you will have to get an optic fiber or coaxial cable depending which cable box you have and connect it to the digital input of the Denon receiver. The Denon's digital input are already assigned at the back. Eg: Optic input might be labeled CD so if you are connecting the CBL box to the optic input remember to select CD on the Denon to hear the cable sound, same goes with the coaxial input.
Aug 27, 2011 | Denon AVR-788
I have an avr 3200 can it use 2 coaxial inputs and how good is the sound quality compared to newer avrs
Denon being one of the best names in the biz and this being an upper-crust modfel, I'd say anyone without a 'golden-ear' would be hard pressed to t\distinguish its sound from any other amplifier in existence.
The Denon site doesn't list and AVR-3200, but the AVR-3300 has 1 coaxial digital audio and 3 optical digital audio inputs.
If you're looking to run multiple coaxial devices and there aren't enough inputs this is what I do...
Helpful hint: Coaxial digital audio cables can be joined using an RCA cable splitter so they can share a given input or distribute a given output to multiple places. You just have to remember to have only the DESIRED units turned on when sharing or there will be digital confusion on the buss and it will result in silence or horrendous noise.
Jan 15, 2011 | Denon AVR-3200 Receiver
I have a Denon AVR2307 to which is connected,via optical audio and component video a DVD player/recorder and this works well but in order to take some of the work off the player part I've bought another...
HDMI signal from DVD can not be down converted to analog component signal.
Connect your new DVD to a component input 1..4. Make sure that component input assigned to desired input (dvd/vcr/sat/) (setup - input setup - input - component assign - component x etc). Connect coax output of DVD to coax x input of the receiver and assign it (setup- input setup - "input" - digital assign ..). Probably you need to setup DVD output resolution to 720i or 720p in dvd setup menu.
Sep 09, 2010 | Denon AVR-2307 Receiver
Can you tell me what are the functions of the two hdmi inputs, and the one hdmi output ,as my cable only works via the tv to the dvd player and a coax from dvd to the coax on avr, so hdmi on avr is...
Let's treat this as TWO functions - audio and video.
Your best video would be HDMI output (audio & video) from the cable box and EACH other video source (BD/DVD) directly to your TV and receiver. But, I'd still WATCH the video from the direct TV connection. The fewer intervening cables and electronics, the better.
Your best audio performance will come directly from each multichannel source via a digital (HDMI, coaxial or optical) cable to the receiver. I would LISTEN to audio through the receiver for best quality.
See a trend here? TV's best at video; receiver is the master of audio.
And neither one adds much by handling the other. Usually the opposite.
You mention coax. Do you mean coaxial digital audio????? As coax is also shorthand for the thick black cable bringing video to most cable boxes, connecting antennae to TV's and such.
You don't actually define what the problem is. Only YOU can be the judge of what 'better' is.
There are a multitude of (mis)settings you should master before declaring a hardware problem. I'd dive into the manual.
Aug 03, 2010 | Denon AVR-1508 Receiver
PC Sound Card Connection to Denon AVR-2805 or Samsung 40B610
  • Should I be connecting my pc sound card directly to the receiver or to the tv then to my receiver to get the best sound output? To your reciver
  • When I get the HD Digital Tuner, does that make any difference for the pc connection?
  • Try to connect everything that is sound onto your reciver then
  • connect all your video to your your TV for now
  • When you get your digital tuner connect all your inputs for video to(in order >reciever>HD Tuner>TV
  • Basicly everything goes to your tuner first.
Jan 16, 2010 | Denon AVR-2805 Receiver
I cant make the coaxial cable work with surround sound
Coaxial cable does not support 5.1 dolby surround sound. You could try setting the unit to Stereo Output instead. Also you could use RCA cables instead.
Jan 11, 2010 | Denon AVR-2802
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
No sound from my Denon AVR-1707
I think that's something in SOUND SETUP menu incorrect. Try to redo it again.
Oct 01, 2007 | Denon AVR-1707 Receiver
Denon AVR-3805 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
