Question about Element Electronics FLX-2210 22 in. LCD HDTV
Sound but no picture, turn set on the element display comes on but after that i get sound but no picture
    Problem Solver:
  • 5 Answers
Are you able to barely see the picture behind the darkness? does the system power down? check to see if your backlighting is blown. These sets are cheap enough now you may be better spending your time grabbing some extra time at work and buying a decent quality tv in the first place.
Posted on Feb 18, 2010
I have an element tv that isn't displaying picture only sound.
Most likely it's the LED driver. It could be on the main board or the power supply board. These people can get you the correct parts: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 16, 2017 | Element Televison & Video
What does the digital board do in a element tv work? My tv screen goes to a solid color can hear sound but can't see the picture. Had the main board changed and that did not help
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Fault to Display Panel to all LCD TVs are almost similar, irrespective of its screen size and brand.
Dec 11, 2015 | Element Skateboards Element ELGFW551...
My 42 inch element flat screen has sound but no picture
dim the lights in the room, turn on the set and shine a bright flashlight on the screen. Do you see a faint picture?
Feb 06, 2013 | Element Electronics PLX4202B 42 in. Plasma...
I have the ELCHW261 and it comes on when powered up but the picture is black and the sound is great, What can I do to get the picture back?
Sounds like you have a backlight fault. To verify this, turn on the TV, dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture you have a backlight problem. Do you feel comfortable opening up your set?
Jan 16, 2013 | Element Electronics ELCHW261 26 in. TV
Cuts off shortly after turning it on
Sounds like you have a short some place, and it needs to be replaced.
Dec 25, 2012 | Hamilton Beach 33966 6-Quart Slow Cooker
Kenmore Electric Range Model # 790.95664100 All display lights are off until you turn on a heating element control knob. Then the time display starts flashing "12:00" along with a short buzzing sound...
Sounds to me from the information you provided that the auto timer is set...when the auto timer gets set you are generally unable to use the oven. If the auto timer is not set then you are looking at a problem with the Electronic oven control..do any error codes show up f1 - f2 - f3 and so on?
Jun 23, 2009 | Kitchen Ranges
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
Oven control panel
Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
set the oven temperature, set the time(s) and to set up your range. To use the
touchpad, press the center part of the pad with the flat part of your fingertip. A
beep will sound to indicate that the selection has been made. Turn the dial to the
desired setting and press START.
Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
Clock time display can be turned off. The default display is on.
1. Access SELECT FUNCTIONS Menu.
2. Turn knob clockwise until CLOCK DISPLAY is displayed.
3. Press START.
4. Turn knob to select ON or OFF
5. Press START to accept new selection.
Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
2. Turn knob clockwise until RESET DEFAULTS is displayed.
3. Press START. Display reads SELECT FUNCTIONS.
Dec 03, 2007 | Bosch HES 24 / 6HES 242 / HES 247 Electric...
Element Electronics FLX-2210 22 in. LCD HDTV Logo
786 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
