Question about Car Audio & Video
Have 2000 passat. After having interrior detailed, I am now unable to change stations on the radio and the display displays garbage, unreadable stuff. The radio does work however cannot change from AM to FM or change stations. What do you think is wrong, what is correction, and how do I remove the radio.
  • 3 more comments
  • jsitrin1 Oct 03, 2009
    tried your suggestions including disconnecting battery. Situation is still the same, also you have not advised how to remove radio?
    I disconnceted the battery and let the radio dry out for 2 weeks and the problem still exists. Please advise against the original questions.
    Can you give me specifics on how to get the radio out? I have a factory installed Monsoon. Are you a VW person?
    At th9is point I need accurate instructions on how to remove my radio. Factory installed Monsoon in 2000 Passat
  • jsitrin1 Oct 04, 2009
    Hi
    Appreciate your comments. I did disconnect the battery, however I did not put the code back in. I have the code as it is in my manual. I'll try that and see what happens. The problem occured sometime when the car was being detailed. Either the detailer sprayed something on the radio, which he claims he did not, or he may have pressed a bunch of buttons while the radio was working and got it convused. the result is the buttons do not work, the display dsplays garbage, and some of the other buttons do not work. The radio plays , but one cannot chnage the station without going thru a lot of girations.
  • 386 Answers
Try disconnecting the battery and then re-install your security code, you can obtain your code from a dealer repair invoice or by visiting a VW dealer and showing proof of ownership to a service manager.
It's just a matter of resetting the unit back to default settings.
Posted on Oct 03, 2009
  • Jeff Phillips
    Jeff Phillips Oct 03, 2009
    I did not read anywhere in your description that the radio got wet, ( as per dry out comment) just noticed, well if you radio got any amount of moisture at all it is junk now, you will need to remove it, yours requires a special tool for removal , go to www.crutchfield.com they will have the tool as well as all technical advice available for your model...
    President:
  • 1,015 Answers
It sounds like they may have used some cleaning soloution on the dash and may have got it into the radio face. I would definently have whoever detailed your vehicle pay for the repairs on the radio or install a new one. But if you want to try to fix yourself you could try a few things to try and remedy the problem. You may be able to get the radio working again by pulling the fuse for the radio then using a air compressor or a can of compressed air to try and remove any liquid inside the radio panel. Hit the buttons with compressed air in the cracks working from the center outward. Hopefully you will see the liquid making it's way out of the radio panel. Depending on what cleaning soloution they got into the radio you could also try and use a hair dryer on the radio to try and dry out the panel. If the substance/soloution is oily or hydrocarbon based you may not get so lucky. You would then need to remove the radio and remove the facepanel of the radio and use a q-tip with rubbing alchohol to remove the residue causing the problem. Then re-install the fuse and see if it works. Now even after these steps the radio could still be permanently damaged and could need replacement. I would notify the place that detailed your vehicle and try to get them to have it repaired. But it will be your word against theirs. Let me know if you have more questions.
  • 1 more comment
  • muebe Oct 03, 2009
    Sorry I cannot see your previous comments to other experts until after I post a soloution.If you let it dry out for two weeks that should have been enough time for it to dry out...I would still try the compressed air. As far as removing the radio is a factory or aftermarket radio? The instructions will be a little different for reach type of radio. But usually the housing around the radio(dash) is held on by screws or clips. Once that is removed you can get to the screws that hold the radio inside the dash. Some vehicles require alot of dis-assembly of the dash to remove the radio while others do not. I would need to look at the picture of your dash to further help you with the radio removal.
    On a VW you need special release keys. They are inserted into the front of the stereo where the right arrow button is and the left double arrow button is. You will see two small slots if you look closely at the stereo. These keys are pushed into the stereo and then release the locking mechanism and the stereo will pull out of the housing. Here is a link to a webiste that carries these keys http://www.radio-release-keys.com/volksw...
    The only sites that I could find where the keys are avaible are not in the United States...The one site I did find said the keys were out of stock and no longer available. It may be possible to find them on e-bay. Let me know if you have other questions.
  • 615 Answers
They did apply something that effected the unit try to use air spray to dry/clean it and remove any wax on the unit then you can reset the unit by taking the battery cables off and connecting them again (for at least 3 min.)...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 27, 2009
My Philips AJ3980 radio suddenly has no sound. Also, the band "MW" appears in the display and I'm unable to tune AM stations. The clock seems okay. Thanks for your help!
1. Press the RADIO button to switch on the radio.
- Radio touch screen controls appears throughout
radio operation
- The radio frequency and waveband appears in the
display for 10 seconds before reverting back to the
clock display.
2. Press the BAND button to select your waveband FM/AM.
3. Tune to your station manually or automatically
by using up / down.
Here is a figure to help find the control buttons:
Please change waveband to FM.
Thanks.
gylacz
Jun 20, 2011 | Philips AJ3980 Clock Radio
I have code '0832' for radio Beta /Passat 1999, but i can't enter it , what the methode?
Hello! If the battery has been disconnected and the radio was not changed the system will clear on its own...It takes 1 hour, with the radio on, to reset itself...However, here is the procedure...
1. Turn on the Radio... "Safe" will appear in the display...
2. After 3 seconds, the number "1000" will appear in the display....
3. Use the radio station preset buttons 1 to 4 to enter the code number...
Use preset button 1 to enter the first digit in the code number. Use button 2 to enter the second digit, etc... The value range for each of the 4 digits is "0-9"... The digit will increase by 1 each time you tap the preset button... The number returns to "0" after 9"...
4. After you finish entering the code, press the right side (">") of the SEEK button for longer than 2 seconds until you hear an audible signal...
5. If you have entered the code number correctly, "LSM" wlll appear in the display...
If you entered a wrong code number, "SAFE" will appear in the display... Initially it'll flash, then stay on...
You can repeat the procedure again one time...If the wrong code number is entered again, the unit will be disabled for 1 hour... Leave the unit on and the key in the ignition...
Guru......Saailer
Jan 31, 2011 | 1999 Volkswagen Passat
Entering radio codes for a 1998 passet
If you don't have MODE and SCAN buttons ( I didn't ) you can try as above but with TP and TA - they worked for me.
Feb 22, 2010 | 1998 Volkswagen Passat
Radio's display won't light up
The radios in the 2000 Mountaineer are notorious to short out. You simply have to get a new one. Believe me. I had the same problem.
Mar 15, 2009 | 2000 Mercury Mountaineer
Can't see anything on the clock/Radio Display
the radio display is lighted by a tiny bulb inside the radio, to change this u must remove the radio from the dash and take off the top sheet metal cover, under that u will see a small twist in bulb socket, replace that little bulb, the bulb is about $2 and avail at any full sevice auto parts store.
Feb 24, 2009 | 2000 Pontiac Grand Prix
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
Manually change radio stations?
Here is how to manually tune your radio.
1 Press the SOURCE button until a radio
frequency appears in the display.
2 Press the BAND button repeatedly until the
desired radio band is displayed.
Each press changes the band:
→ F1(FM1) → F2(FM2) → AM
3 Press the TUNE button repeatedly until "DX
SEEK" and "SEEK" disappear from the display.
NOTE
The initial mode is DX SEEK.
4 Press the g DN or f UP button to move
downward or upward one step respectively until
the desired station frequency is displayed.
NOTE
The ST indicator or STEREO indicator appears on the
display when a Stereo FM station is tuned in
You can also look at your manual here for any other ? you might have
http://akamaipix.crutchfield.com/Manuals/500/500CDM7874.PDF
Dec 17, 2008 | Alpine CDE-7858 CD Player
1995 V.W PASSAT
If I understand your post right, you have the code but need the procedure on how to input/enter it into the radio. To my understanding, a 1995 Volkswagen Passat would have a non-BOSE unit with or without CD changer controls. It was a premium sound system with anti-theft coding.
Pls try:
1. Power the radio ON till "SAFE" is displayed;
2. Press the AM/FM and SCAN buttons simultaneously till display shows "1000". (In some versions, it is the seek and the two scan buttons);
3. Release the AM/FM and SCAN buttons;
4. Enter your security code using the first four station buttons on the radio;
5. The first button changes the first number of the four digit code;
6. The second button changes the second number and so on and so forth;
7. Once the proper code has been entered press the AM/FM and SCAN buttons at the same time and hold until the radio accepts the code;
8. You have two tries before the system will lock you out for an hour;
9. Should you happen to have a three digit code, pls make the first digit a zero;
10. The first digit can only be 1 or 0 (the 0 will not show up so for a zero, push the button until the 1 disappears).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 08, 2008 | Audio Players & Recorders
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
