Question about Microwave Ovens
GE Microwave JVM1660WB - Vent went up in flames
I was cooking a dish that flames up and it flamed before I was expecting it and the flame went up the vent. The charcoal filter was actually on fire for a few seconds. So now when I try to use the vent it makes a very loud sound. It runs but it is scary noisy.
Any ideas or is it time for a new one?
Thanks
  • Microwave Ovens Master
  • 8,404 Answers
Definitely time for a new filter.
your oven may be shalvagable. Id remove it all take the cover off to inspect for damage.
I hope this helps
No more flaming foods in the micro!
Posted on Sep 27, 2009
Flame Sensor not available
We could look it up if we knew your full model number, but some of their budget models (like some made for Wal-Mart) are made with only turntable parts available.
Within the warranty period, the oven is to be returned to the dealer.
But a fire would not normally be covered under warranty unless the oven came on by itself when idle.
Otherwise, the thermostat / TCO has temperature markings on it, and a generic equivalent or very close type can be matched at a local appliance parts store.
May 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
What caused this to catch on fire?
its the grease that has got into it replace it and allways keep it clean
Dec 06, 2011 | Frigidaire Microwave Ovens
Flame safety device
The "Flame Safety Device" is a flap that closes over the cavity vent in case of flames from burn overcooked food in the cavity. It also turns the oven off.
I have never tried this however!!!
Jan 04, 2011 | Microwave Ovens
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
Sep 15, 2010 | Microwave Ovens
Arcing... can I still use the oven?
The microwave energy is not ionizing radiation, so the real risk is further arcing and possible fire.
The cavity will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Jun 04, 2009 | GE Profile Spacemaker Over-the-Range...
GE Microwave dead
Chances are the flames opened the oven cavity TCO, which acts as a flame sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some components (cavity TCO) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jan 31, 2009 | GE JVM2070 Microwave Oven
Exploded a musical mug in spacemaker xl1800 microwave.
If there's no damage it should be fine.
I would double-check for cracks, especially in the inner door glass and the screen / mesh.
If it looks fine, heat a cup of water in a microwave-safe container for about 2 minutes and see if it cooks without arcing or odd noises and that it boils in about 2 minutes.
As always, never leave a microwave unattended while running.
Jan 28, 2009 | GE XL1800 1100 Watts Microwave Oven
How to replace thermal fuse/flame sensor
GE JES 1358 WK 01 microwave:
I recently had the same problem with a "flame sensor, " aka "thermal switch." My microwave is a "throwaway" model, very few repair parts available. I didn't want to replace it, so I did a little bit of research into thermal switches. I actually found one that would replace it for about $5 (plus $5 shipping).
Mine uses a "bimetal" thermal switch. There are three kinds of bimetal thermal switches: automatic reset, manual reset, and "one time use." The really interesting thing is this: the "one time use" resets (!!!) if the ambient temperature is below 0 degrees C, or 32 F (freezing); or, in some cases, -31 C, or about -22 F.
I put my "dead" flame sensor in the -10 F part of the freezer for about 20 minutes...
Checked it with my multimeter, and the once-dead sensor now read continuity (zero ohms)!!!
Reinstalled it in the microwave, and now it works fine.
So if you have a dead sensor- try freezing it...
Sep 21, 2008 | Microwave Ovens
Runs but makes a super load pop sound with flame
It sounds like you're saying a flame and pop came out of the area where the internal electronics are? If that's the case, then I would suspect a failed high-voltage transformer, bad magnetron or that another high-voltage component is arcing, like maybe damaged wiring, but that's rare unless... ... I hate to suggest it, but maybe a "critter" has made his way into the high-voltage section! That can cause some really "interesting" effects! If the flame and pop are coming out of the cooking cavity, then it could be food debris or grease underneath the waveguide cover or in the waveguide. I would say the likliest cause is a failed HV transformer. If it's still under warranty, I'd call Sears right away to verify that. If it's not under warranty, you may want to pull it from the wall yourself and take it in to Sears or another shop yourself. You'll probably save about $50 as opposed to letting them come out to the home to service it.
Oct 04, 2006 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
