Question about RIM BlackBerry Storm 9530 Smartphone
My phone will not turn on and there is a battery icon with a electrical bolt through it
  • 31 Answers
You need to plug in your iPhone, and then wait about five minutes.
Posted on Sep 27, 2009
What does a Nuvii 55 LM screen green icon with lightning bolt mean ?
The lightning bolt indicates that the battery is being charged. Remove the unit from the charger and the lightning bolt will go away.
Feb 07, 2016 | Garmin nuvi 55LM 5" GPS with Lifetime Map...
2005 Dodge stratus 2.7L V6 DCOH 24 valve electrical problems.Alternator wont charge battery. good alternator/ good battery
WOW Jose you have done your fair share of things , you said you tested alt 3 times , with it running do you show power going from alt to batt ?,is there by chance a inline fuseable link in power lead to battery from alt ? some cars have a alt fuse that stops batt from reciving power ,incase of short or power surge ,that's the best I can do right now I will look into it further , if you get a chance PLEASE wright back ,even if you fix it you really got my interest . good luck I hope I gave you some thing to go on .Woody
Aug 28, 2014 | 2005 Dodge Stratus
How so I know if my htc freestyle is charging?
This question is very broad as far as the questioning, but what I would do is plug in my charger and see if my battery icon indicates that it is charging. The battery icon may have a numerical percentage or not, that turns into a wall plug or a lightning bolt. You can also check battery status under the 'Settings' menu and can be usually found in 'About Phone'. I hope this gives you an idea on how to know if your HTC Freestyle is charging.
Jun 30, 2013 | Cell Phones
2003 Kia RIO WHEN TURNED TO ON CAR starts and the starter will not stop turning
Replace the starter.
Removal & Installation
1.5L & 1.6L (VIN 5) Engines
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Remove the 4 upper intake manifold stay bracket bolts.
  4. Disconnect the starter electrical connections.
  5. Remove the upper starter bolts.
  6. Remove the lower starter mounting bolt(s) and the starter.
    Fig. Starter mounting-1.5L and 1.6L engines
To install:
  1. Install the starter.
  2. Install the lower starter bolt and tighten to 27-38 ft. lbs. (37-52 Nm).
  3. Connect the starter electrical connections.
  4. Install the intake manifold support bracket and finger-tighten the 3 mounting bolts. Tighten the lower bolt to 27-38 ft. lbs. (37-52 Nm).
  5. Install the 4 upper intake manifold stay bracket bolts and tighten to 27-38 ft. lbs. (37-52 Nm).
  6. Install the upper starter bolts and tighten to 27-38 ft. lbs. (37-52 Nm).
  7. Connect the negative battery cable.
1.6L (VIN 3) Engine
  2. Remove or disconnect the following:
    Negative battery cable Air intake assembly Shift cable and bracket Starter electrical connections Starter
To install:
  1. Install or connect the following:
    Starter Starter electrical connections Shift cable Air intake assembly Negative battery cable
May 04, 2011 | Kia Rio Cars & Trucks
How to remove starter
Removal & Installation - Starter
  1. Before servicing the vehicle.
    Negative battery cable Radiator air baffle assembly
    Electrical connections Torque converter cover Starter
To install:
    Starter. Torque the bolts to 35 ft. lbs. (47 Nm). Torque converter cover Solenoid -BAT- terminal. Torque the nut to 89 inch lbs. (10 Nm). Solenoid -S- terminal. Torque the nut to 27 inch lbs. (3 Nm). Radiator air baffle assembly Negative battery cable
  2. Perform a charging system test and verify the starter is operating properly
Fig. Showing the starter motor location and electrical connections
    Negative battery cable Radiator air baffle, for clearance if necessary Flywheel inspection cover bolts Flywheel inspection cover Electrical connections from the starter motor Starter motor mounting bolts Starter motor
To install:
    NOTE Before installing the starter motor to the engine, tighten the nut next to the cap on the solenoid BAT terminal. If this terminal is not tight in the solenoid cap, the cap may be damaged during installation of electrical connections and cause the starter motor to fail later.
    Starter motor Starter motor mounting bolts and tighten the bolts to 30 ft. lbs. (40 Nm) Electrical connection to the battery terminal on the solenoid and tighten the battery terminal nut to 13 ft. lbs. (17 Nm) Electrical connections to the S terminal on the solenoid and tighten solenoid S terminal nut to 27 inch lbs. (3 Nm) Flywheel inspection cover Flywheel inspection cover bolts Radiator air baffle, if removed
  2. Connect the negative battery cable
Hope helps, remember rated this.
Aug 12, 2010 | 2001 Pontiac Montana
No power will not trun on
Hello
Plug in the printer power cord into electricity to charge the battery.The battery might need charging if the On light flashes green it indicates that the battery is charging.
Switch ON the printer, the battery charging icon (lightning bolt icon) flashes above the battery icon on the printer screen to indicate that the battery is charging.
If the battery is charged and the printer does not turn on with the battery power, unplug the printer power cord, if it is plugged in. Open the battery compartment and remove the battery. Wait for about 10 seconds, and then reinstall the battery.
An empty battery should fully charge in approximately four hours when the printer is not in use. If the battery still does not charge in 4 hours,you should replace it
Good luck
Apr 23, 2010 | HP PSC 2210 All-In-One InkJet Printer
My blackberry 8520 turn off
try these steps.
1.. borrow same battery from a friend and insert it to your phone and switch on.
2. borrow same type of charger and charge your phone and wait to check.
3. else, try, inserting your battery to your friend's phone and check if her phone will power on, but be sure to let him know of your problem, so she or he may be aware of it. , hence, just do step 1 and 2,
4. go to your nearest service center and have them check your phone.
Feb 21, 2010 | RIM BlackBerry Curve 8310 Smartphone
How do i fix a zire 21 palm it wont turn on, charge,work nothing
Hello.
From Palm support:
1. Press either the Date Book or Address Book button to see if
you can turn on your handheld that way.
2. Perform a soft reset: Use the tip of an unfolded paper clip
(or similar object without a sharp tip) to gently press the
reset button inside the hole on the back panel of your
handheld.
3. Make sure the power adapter is plugged securely into a
working electric outlet and is firmly connected to the
handheld. (If no outlet is available, your handheld can also
be charged through the USB cable, but this takes much
longer.)
Note: Your handheld does not have an indicator light to indicate that your handheld is being charged.
4. Charge for another three full hours.
5. If your handheld now turns on, check the charging-battery icon to ensure that your handheld is being charged. Example:
a. Connect the handheld to an outlet and turn it on.
b. Tap Home .
c. Look for the lightning bolt on the battery icon at the top of the screen.
d. If you do not see the lightning bolt, repeat steps 3 and 4.
Hope this helps.
Nov 03, 2009 | Palm Zire 21 P80730US Handheld
Micron Trek 2 laptop won't start on battery or AC (NBKU375)
The lightning bolt is used to indicate an electrical problem but then, you know that already :-( Try removing the battery pack and start it from AC only; some battery types don't like to be ignored, they can have individual shorted cells.
Sep 30, 2009 | Computers & Internet
I would like to turn off the flash.
Electric sign is used as flash sign in digital camera.
Below is an image of that sign...
Jan 06, 2009 | Canon PowerShot A75 Digital Camera
RIM BlackBerry Storm 9530 Smartphone Logo
114 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
