Question about Acer Computers & Internet
Acer 5920-6864 ac plug only works when pulled to 1 side
    President:
  • 2,600 Answers
Either the center pin on the dc plug or the small tension band inside the DC jack is loosing its spring, this spring action is what holds tension on the shaft of the pluug. The center pin that conducts the positive charge tends to break its solder point and therfore the chrge unless it is manipulated, the jack at this point needs to be replaced.
Posted on Sep 27, 2009
My Acer Aspire 5810tzg won't start, I've check the power cable and battery and they work fine on other machines, it just won't turn on
There is one thing you can attempt before seeking repairs. You should try a power reset.
1) Unplug the AC adapter
2) Remove the battery
3) Hold down the power button for 30 seconds and then release it
4) Insert battery
5) Plug in AC adapter and see if the laptop can power on
If it does not power on, you may need to seek support with Acer.
Oct 24, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
1. Unplug AC adapter. Shutdown
2. Remove battery, Connect AC Adapter
3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
5. Power up -
Now Plugged in and Charging.
Aug 04, 2011 | Acer Aspire 5520-5908 Notebook
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
Acer 3860 no power
Contact your manufacturer for further assistance.
Jul 29, 2010 | Acer Aspire 3680-2682 Notebook
My 4520 Acer Laptop will not charge and will not work on AC power alone.......
You First need to test your AC Adapter Cord...
You can test if you have a secondary known working one.. plug that one in to see if same issue occurs.. OR you will need to test the AC Adapter using a multimeter (available at any home improvement store for under $7).. When testing the Plug End on the AC Adapter - Hold The Negative Test Prod Of the Multimeter to the Outer Side Of the Plug Tip, and Put The Positive(red) Test Prod Inside The Plug Tip... See If You Have Power Through The AC Adapter Tip... You Might Need To Slightly Wiggle The Cord Near The Tip End To See If THere Is A Short In The Cord....
If Cord Tests Good....
You Will Need To Replace The Laptops DC Jack...
The DC Jack is the port where your AC Adapter Plugs into on the laptop..
Your Faulty DC Jack Would Need to be desoldered, the motherboard cleaned of all old flux, Re-Tin The Contact Pads and then Resolder a New DC Jack Onto The Motherboard...
Nov 16, 2009 | Acer Aspire 4520-5582 Notebook
I cannot find the compatable AC adapter for my ACER Extensa 5420-5687 on the ACER web site. Are all the 65W adapters the same for ACER
If it requires a 65W adapter, then any universal adapter will work and probably be cheaper. or off ebay: http://cgi.ebay.com/AC-Adapter-Charger-Cord-for-Acer-Extensa-5420-5059_W0QQitemZ290306848179QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4397a2f5b3&_trksid=p3286.c0.m14&_trkparms=65:12|66:2|39:1|72:1205|240:1308|301:1|293:1|294:50
any 19V 3.42Amp adapter with the right tip will work.
Jun 16, 2009 | Acer Extensa 5420-5687 Notebook
Acer laptop Aspire 7000 does not power on
If the laptop does not power up (not a slight sign of power flowing through it) even if the AC adapter is plugged into it, here are the possibilities:
1. You AC adapter might be broken and need to be replaced. Some AC adapters have a light on it to signify that there's power flowing from the power outlet to the power cable.
2. If your AC adapter is working fine, maybe your power supply is broken. If your laptop is with in warranty, have Acer replace it. If not, find a repair center who does.
Apr 10, 2009 | Acer Computers & Internet
Computers & Internet Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
