Question about Dell Optiplex GX280 (99301) Motherboard
Over heating My dell optiplex gx280 overheats. It has the factory heat sink and aftermarket fan. Is it possible the processor has been overclocked? How do I tell
  • skipy101902 Sep 29, 2009
    Thank you, I'll check it out
    Thanks, I'll give it a shot
    President:
  • 1,187 Answers
Overclocked check:
Right-click [My Computer]
Select "Properties"
The [General] tab has the PC specs at the bottom.
Note the CPU model identifier (example: Intel 2 6400 @ 2.13GHz)
Now find the correct specs for that CPU (through Google?)
If the eral] tab shows a higher CPU clock speed, the CPU is overclocked.
You can change the clock speed in the BIOS setup.
I hope this answers your question.
Posted on Sep 28, 2009
    President:
  • 2,600 Answers
No thermal grease or old dry thermal grease and a dust and debris filled heatsink is your most likely cause of this problem. Dell isn't very overclocker friendly...it is more likely a lack of maintenance in blowing the dust out of the case on a regular basis. Take the case panels off and use dry compressed air to blow the system out and clean it thoroughly. The heatsink needs to be removed and the hold down latch on the processor needs to be removed and the heatsink and processor need to be wiped clean and a new thin layer of thermal grease applied to the processor. Put the system back together and fire it up.
Posted on Sep 27, 2009
Dell inspirion 1545 respond slow and shuts down even when on the desktop
The most probable, as far as I know, the hard drive is dying. Please test the laptop with a healthy (or brand new) hard drive.
Feb 18, 2014 | Dell Inspiron 6400 Notebook
I need only circuit schematic diagram
Restart it or get off of gamesites or things like, Minecraft, Call of Duty, Terraria, and others like those. If a game takes a little to load and after a while you can hear the fan getting louder you can do something else until the fan starts to slow down a bit.
Dec 25, 2013 | Dell OptiPlex GX280 PC Desktop
Overheat and shuts down
Following are the reasons for overheating, just take care of these things::
  • Stop Overclocking your CPU
  • Make sure your Heat Sink is placed properly above the processor
  • Clean the Processor fan, Heat Sink and other peripherals
  • Use High Speed fans
  • Use CPU Heat Sink Paste in the processor
  • Make sure your dint restrict the speed of CPU fan.
  • Use Additional Cooling Units
Also use a system utility tool like PCFresher to fix windows errors.
Apr 25, 2012 | Computers & Internet
Dell optiplex GX280 PC when power on system no noise with fan after one hour making loud noise . I changed the CPU fan , also same noise, and applied heat sink paste to CPU and heat sink same noise....
There probably is another fan, located inside the power-supply, that is making all the noise.
Borrow a stethoscope from a nurse or doctor, and listen to the noise, to pinpoint "where" on the computer that is the origin of the noise.
Jul 16, 2011 | Dell OptiPlex GX280 PC Desktop
Optiplex GX280 - loud fan at start up and amber power light - does not boot and no light at the back
Apply pressure on the heat sink fan right before you press the power button and continue applying pressure. Watch your screen if you see it boot this means its a problem with your processor clamp that applies pressure to the processor. Try to remove the top part of the clamp. Shouldn't be too hard with some needle nose pliers. Then just replace the heat sink and fan with out that clamp.
May 27, 2010 | Dell OptiPlex GX280 PC Desktop
I have Dell GX280 system. My Fan produces more sounds and runs fast. System Hangs while processing and performs slow, causes processor nore hot. I pasted the Heat Sink Paste on processor that resuls in low...
More than likely your fan needs to be replaced. These small form factor Dells are know for problems like this. Warning! Do NOT attempt to blow out the CPU fan with canned air, as this will likely lodge dust particles in the axis of the fan causing it to drag and become louder!
Sep 09, 2009 | Dell OptiPlex GX280 PC Desktop
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
Computers & Internet Logo
278 people viewed this question
Alun Cox
