Question about Amana SXD524VW Side by Side Refrigerator
Amana Spare Parts
Hi - We have a Amana Side by Side and the Ice box / tray is smashed (the one with the coil inside). I have been searching for a place to buy a spare but with no luck . The model number is SBDT520/JW. Can anybody help me?
  • marianm Jun 19, 2008
    we need the vagetable draw for amana model AS-2126
    ITEM NO: 61006110
    2211B 2800502
    it is a side by side frige .
    thank you
    e- mail :
  • 410 Answers
Not sure if this will help as they dont have any parts imaging but check here hope this helps..
Posted on Dec 18, 2007
Ice maker not making ice
Check and see if a cubes or cubes are stuck in the ejection fingers. If the ice mold is full try cleaning the bottom coils. If the ice mold is empty check the water valve solenoid. Most times both the ice maker and water valve gets replaced at the same time. Nothing inside the ice box controls the ice maker. It does it all itself all it needs is for their to be 35f in the freezer or better.
Apr 06, 2014 | Amana ARSE66MB Side by Side Refrigerator
Hi, I am Dennis. The unit leaks water from the vent in the bottom center of the freezer side on to the floor of the freezer and sometimes out of the freezer door to the kitchen floor. Not muck of a leak....
Abesolutely a bad defrost heater. it is too weak to defrost the ice completely, therefore it falls off the coils and freezes on the drain tray. If you dont want to replace the heater you can also just install a drain tube heater that wires into the evaperator fan, it will run constantly as the fan does to keep water from freezing in the tube or tray. All parts can be purchased at using your model number.
Nov 30, 2010 | Amana ASD2622HRQ Side by Side Refrigerator
Refrigerator coils are iced up.
check heater and bimetal. check timer. seems like unit isnt defrosting
Feb 08, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have an amana side by side refrigerator. The ice is building up
There is a drain hole under all of that ice that got clogged at some point and it started building up ice in that area.  The water that is freezing is coming from the defrost cycle which melts all of the ice buildup on the evaporator coil.  First melt the ice.  Then unclog the drain hole.  The drain goes to a tray in back near the compressor, where the heat from the compressor evaporates the water.
Oct 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker isn't working...
looked up a part number using your supplied model, its listed as anicemaker assy (220v) complete assy 67006665
Mar 22, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
455 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
