Apparently, you pulled out the paper with the printer on; that's wrong if so. Then it is likely you pulled it out jammed paper from the wrong side, (always pull out jammed paper in the reverse/backward direction of the paper movement). This is enough to unsettle your printer. What you should do now is shut down your computer, turn off printer. Then open all the "covers"of the printer, (top and at the back, if applicable) and close all again firmly. Turn on PC and try to print again.
check where the paper was removed, there is a switch or flag that has not been returned to it's normal operating position. (small plastic piece in the paper path) if you cannot find this, it may have been damaged. and you may have no choice but to take it to a certified repair person. make sure they guarantee their repair work.
when i try to print something it only prints dashed lines down the side of the page, what could be...
(More)
when i try to print something it only prints dashed lines down the side of the page, what could be causing this?
hello, the print spooler keeps stopping and now I can't print to any printer. There is a document...
(More)
hello, the print spooler keeps stopping and now I can't print to any printer. There is a document waiting to be printed but I can't print it. I'm using windows vista, and an hp laserjet 1022. I've tried restarting the print spooler but that does not last. Can you help? Thanks.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
