Question about Estate TGDX640JQ Gas Dryer
Ignighter comes on but no gas for main heat - Estate TGDX640JQ Gas Dryer
    President:
  • 1,776 Answers
I would suspect faulty gas valve coils. These electrical coils are above the gas valves and when energized, these solenoids open the gas valves and permit gas flow to the burner. If faulty there is no gas flow and the burner cannot light. It is recommended that if any are suspected of being faulty that both (all) be replaced at the same time and will most likely come from the part supplier as a set. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
Roper gas range. Oven glow coil comes on but has no gas to heat?
if the glow igniter is on and it doesnt light its probably the gas valve
Feb 12, 2012 | Roper FGP300 Gas Kitchen Range
Whirlpool Model LGN2000KQ0 ignighter glows, flame turns on for a few minutes then it goes out and the ignighter never glows again nor does the flame return
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help troubleshooting a gas dryer
Sep 25, 2010 | Whirlpool GGQ8831L Gas Dryer
Dryer won't dry
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor. All of these parts are inexpensive and easy to test and replace.There is a video at http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jun 08, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Ge gas dryer heats up at first but thats it
You need to change out the coil kit.
Mar 13, 2010 | GE Dryers
Dryer won't heat up. Replaced ignighter, still
I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized these solenoids open the gas valves to permit gas flow to the burner. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 11, 2009 | Kenmore Elite HE4 Electric Dryer
Hotpoint gas oven 5yrs old pre heats fine but then doesn't keep temp up.
You have either a faulty oven thermostat, or your oven door seal is faulty. You can check the oven door seal by doing the following (you will need a A4 piece of paper):
Open the door put the paper against the seal, close the door. Now pull the paper slowly out, if there is resistance then the seal is fine.
The oven thermostat test is as follows (you will need a stopwatch):
Turn your oven on to the lowest setting,when it goes to high flame start timing it the oven should cut down within 8 minutes, if this doesn't occur your stat is faulty.
I hope this helps
Jul 06, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Maytag dryer - no heat
If this is a electric dryer the maine thing that goes bad on them is the heater element . If it is a gas dryer I would check the ignighter.
Feb 24, 2009 | Kenmore Dryers
Electric ignighter does not come on in the oven at all
In most cases it is the ignitor itself. Eledtricity goes thru the ignitor and as it gets hot it allows more electricity thru to the gas coils, allowing them to open and let the gas go thru. The ignitors do get weak and will glow but that is all. Not enough electricity can get to the gas valve solenoids and let gas thru. Find a local parts dealer and give them your make and model # to order the part.
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
Estate TGDX640JQ Gas Dryer Logo
74 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
