Question about Ice Cube Maker
Ice not releasing from plate on Viking vuim150drss ice maker
  • 582 Answers
HOW OLD IS THE UNIT, AFTER A WHILE THE NICKLE PLATING STARTS TO WEAR OFF THE PLATE WHICH WILL CAUSE THIS PROBLEM AND THEY ARE NOT CHEAP, ALSO CHECK ON THE BOTTOM OF THE MACHINE THERE SHOULD BE A CONTRPL THAT WILL INCREASE THE TIME OF THE RELEASE CYCLE
Posted on Sep 28, 2009
    Problem Solver:
  • 4 Answers
Replace the evaporator themisister .
Posted on May 31, 2012
Where is the ice maker control on the Viking 2005 regrigerator
I've maker arm above bucket . 2005, thr bucket can overfill that unless the shelf is in place. There is a new ice maker and arm assy which will help that in the future . Hope this helps
May 24, 2014 | Viking VCSB423 Side by Side Refrigerator
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
jhjf
May 29, 2010 | Viking Professional VCSF036D Side by Side...
Viking side by side makes very little ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Apr 09, 2010 | Viking VCSB423 Side by Side Refrigerator
Ice maker on a viking side by side not working
heatman101
ghd65
Mar 21, 2010 | Viking VCSB423 Side by Side Refrigerator
48 " viking ice maker tray frozen no ice
Try replacing
the icemaker unit. I used Supco model RIM943 and its working great. Found it online for $55 on line.
My Viking 48" ice maker has given me a little trouble too. The first ice maker assmble was replaced under warranty. It only came with a one year warranty so when it just went out again I thought I would take a look. Just like you I had no ice. It only take two screws to remove the ice making unit and a quick discount plug. I read up on the unit to trouble shoot it. My Ice maker had the ejection forks stuck in the down (in the ice cubes) postion indicating the unit was out of sync and needed to be completly replaced.
On another note:
I also had a proble with the flapper ice cube door on the outside ice dispenser. Ice cubes would get stuck in the door and would not drop into the cups. This was a lot tougher to fix, but I like figuring things out. Turns out I had some ice that got stuck in the flapper and some how it melted and froze back up to lock the flapper. When the motor came on it sheard a shear pin in a coupling just off the drive motor. I made a home made shear pin and put it back together and all work great now. It was a bit of work to take it all apart and to tell that the motor was good and the relay was working right.
Jul 27, 2009 | Viking VCSB423 Side by Side Refrigerator
Viking under counter ice maker stopped making ice... ugh.
This unit senses the "freeze plate" temperature to decide when to go into "harvest". Either the the temperature sensor (most likely called an evaporator thermsitor) is lying to the control or the plate is not getting cold enough due to a sealed system issue (usually a bad hot gas valve). If you carefully loosen the front grill (staying clear of the wires going to/from the ON/OFF/CLEAN switch) you can see the hot gas valve near the center in the bottom of the mechanical area. If the copper tube coming out of the bottom of the valve is cold during the freezing cycle...it is bad. If not, I would try the thermistor first. If you do not feel comfortable doing this, you should contact a servicer to diagnose the unit for you. Good-Luck.
Apr 25, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Viking Ice Maker Leak
have you cleaned the machine lately? the float may be dirty and getting stuck and not shutting down the water as it should.
Jan 06, 2009 | Viking Refrigerators
Viking VCSB423 side by side icemaker
You could empty the bucket when full for the days leading up to a party and save the ice somehwere......or buy an Ice machine
Sep 12, 2008 | Viking VGSC306-4B Gas Kitchen Range
Ice Cube Maker Logo
362 people viewed this question
Top Ice Kitchen Appliances - Others Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
ray gallant
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
