Question about Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range
MY STOVE WON'T GET UP TO BAKING HEAT - Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range
    President:
  • 1,304 Answers
If it only gets to 160-170 your bake coil has blown
and your preheating on the broil element
Posted on Oct 03, 2009
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
Maytag accellis 2x stove won't heat-up, does power-up, light comes on but no heat
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Jun 02, 2012 | Maytag Stove / Oven / Range Cooktop -...
I have a Gas Amana Range. The stove top works fine, but the oven will not heat when I select a temperature or broil. I can hear it making noise, but still no heat!
Hi.
If the oven is not baking or broiling test the temperature probe sensor located inside the oven cavity. To test the sensor read impedance (Ohms) using a multimeter. If the reading is infinity, then the sensor must be replaced.
If sensor is OK, the problem is usually either broiling or baking. In that case check igniter and valve coils, the flame sensor does not fail very often.
Regards.
Ginko
Jul 08, 2011 | Amana Kitchen Ranges
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
A wire is hanging from the stove top down into the oven with no where to go. The stove is an old gas Kenmore slide-in. Will the house blow up if I use the oven? Any idea what this wire is for?
Are you sure that it is a wire ? It could be the capillary tube that has had the bulb broken off. The t-stat has a hollow tube (capillary) with a bulb on the end that senses the temp in your oven & tells the oven when it reaches the set temp to shut the heat off. The bulb usually is found towards the top of the baking chamber on either side or at the back. If this bulb is broken off, the t-sat needs to be replaced. There should be NO wires inside the oven, all wiring is routed on the outside of the baking chamber & is protected from the heat by a blanket of insulation.
Jul 09, 2009 | Ovens
Stove top burners and lower baking element not heating up
If all the elements are dead, check for blown fuses/tripped circuit breakers. There may be some in the range unit itself in addition to your electrical service panel. If one element is completely dead on all heat settings, the control is probably bad or there is a broken wire. If it is stuck on high for all control settings or is erratic, the control is bad - replacements are readily available and easily installed.
On ranges with push button heat selection, a pair of heating elements are switched in various combinations across 120 and/or 240. If some heat settings do not work, the most likely cause is that one of the heatings elements is burnt out although a bad switch is also possible. Kill power to the range and test the heating elements for continuity with resistance meter or multimeter.
For the lower baking element:
Again, check for blown fuses in the oven or tripped circuit breakers. The remove any wiring to the bottom element and test for resistance. If you get no reading (or a very high resistance) then your element is dead.
May 09, 2009 | Kitchen Ranges
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Baking element
Hey there. make sure the clock in on manual and not automatic is should show a little hand and not a 0 :)
Sep 05, 2008 | Kitchen Ranges
Baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Maytag Admiral LER3330AAW / LER3330AAZ / LER3330AAB Electric Kitchen Range Logo
245 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
