Question about Kitchen Ranges
While using the broiler, (door was slightly opened) all knobs melted and are very cracked and sharp. GE Profile Convection Gas Stove. Will GE replace with burn-resistant knobs? This stove is only 4 months old.
  • bonniehk Sep 27, 2009
    I need some detailed info on why all 4 knobs on my almost new GE Profile Spectra JGBP90 gas kitchen range melted and now are very difficult and sharp to use? The door was left slightly opened while broiling on LOW. Will GE replace these with better quality? Could a fire arise from the extreme heat. Thank you.
  • 11,896 Answers
They do sell fire-proof and porcelain and more. Go to repairclinic.com to see if they have them for your system
Posted on Sep 27, 2009
  • 8,197 Answers
No Ge will not replace the knobs with new. The reason why is the door was left open slightly. You will need to buy new knobs for the oven. I do not think they make burn-resistant knobs. you will need to contact GE here
GE Answer Center®
1-800-626-2005
Monday - Friday: 8 a.m. - 10 p.m. ET
Saturday: 8 a.m. - 7 p.m. ET
Closed Sunday.
GE Genuine Parts
1-877-959-8688
Monday - Friday: 8 a.m. - 7 p.m. ET
Saturday: 8 a.m. - 5 p.m. ET
GE Warranty Management
1-800-626-2224
Monday - Friday: 8 a.m. - 8 p.m. ET
Saturday: 8 a.m. - 4 p.m. ET
Good luck
GE JGSP28 Range broiler problem: flame comes out when door opened
The air shutter should be completely open. A possible adjustment may be necessary towards the closed position. The orifice needle at the orifice hood may be too tight. Take a 1/2 inch open end wrench and turn the hood counterclockwise to reduce pressure on the needle. Do this with the air shutter completely open. Your flame should reduce in size. The best flame would be about 1 inch long with white tips.
Make the adjustments with the flame off. Then light it and check it. If more adjustment is necessary,turn the broiler off before adjusting.
Sep 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Burner knobs melt on GE Profile XL44 gas range.
I had the same problem and searched extensively for a solution. They even have a video from GE on the net telling you how to avoid melting them, which is basically don't open to broil and make sure the seal is good on the oven. Essentially, don't use their oven normally like the rest of the ovens in the world. Finally I went to a few show rooms to look for a knob to substitute for the garbage ones from GE. On one of the new models they have a solid cast stainless knob (with a plastic shaft, I think it is delrin) which looks identical but has a longer shaft. I obtained the PN which is WB03T10262 and ordered one. I trimmed the shaft length to match the length of the defective knob with a hack saw, and had to trim out some mold flashing in the cavity. After a couple of fittings I was finshed and it looks fine. I then ordered 3 more from the Appliance Zone for $15.98 each. GE's price for the same part was $25.25!!
Jul 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile range knobs melt
Same problem as well. Hoping to buy universal fit parts as GE wants $16/piece (x6) to replace the knobs. They WILL NOT cover under warranty.
HORRIBLE SUPPORT, POOR QUALITY PRODUCT!
Jun 13, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Electric Stove Broiler doesn't stay on
If the door is closed the broil element will cycle off an on normally. It should stay on most of the time if the door is in the broil position (partially open). If your range has an electronic control it will probably also have a hi and low broil setting. On low broil it will cycle off an on even with the door open but more with the door closed
Dec 31, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile JGS968 fan comes on no ignition on gas bake convection bake and roast . Only broiler works otherwise themp always read 100 Degress
natural gas or propane? is this a brand new stove? or did this just start happening? is the gas shut off at the oven turned on? there are saftey features that shut off the gas so you dont get hurt. be carfull
Dec 09, 2007 | GE Profile JGS968 Gas Kitchen Range
Funny Smell
ALL YOUR FLAMES SHOULD BE CLEAN BLUE FLAMES WITH NO WHITE OR YELLOW TIPS OR FLAMES !!!! YELLOW FLAME = DIRT OR PAINT? WHITE = LACK OF AIR SOUNDS LIKE YOUR STOVE IS NOT GETTING ENOUGH COMBUSTION AIR. INPROPER AIR ADJUSTMENTS OR LACK OF AIR WILL CAUSE A WHITE TIP ON THE FLAME ... THAT IS CARBON-MONIXIDE !!! A CLEAN BLUE FLAME EMITTS CARBON-DIOXIDE AND IS NORMAL. IF YOU USED AN AIR-GUN TO PAINT, CHANCES ARE YOUR BURNERS HAVE A SLIGHT COATING ON THEM AND HOPEFULLY WILL BURN OFF IN TIME. TRY OPENING ALL YOUR DOORS AND WINDOWS IN YOUR HOUSE ... AND TURN ALL BURNERS ON AND LET THEM BURN FOR AN HOUR. DO NOT LKEAVE SIGHT OF THE STOVE, BUT KEEP NEAR A OPEN WINDOW. NOTICE !!! MOST GAS COMPANIES WILL COME OUT AT NO CHARGE TO CHECK GAS, AND FOR CARBON-MONOXIDE.(C0) NOT (CO2).
Apr 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
