Question about Samsung WEP-150 Wireless Headset
When plugged charger in the device turns red than turns blue immediately. the device will not power on!
Getting the same as whats the answer
Posted on Nov 19, 2009
Why My Nokia BH 505 Stays Blue When Charging?
Do an Hard reset. Plug charger into the headset, press and hold power button and plug the charger into AC, light indicator will change after a while from red to green/blue.
Feb 14, 2014 | Nokia BH505 Bluetooth Stereo Headset
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Battery ran low...recharged it but will not power on now
Connect the device to the wall charger. Hold the on/off button for about 5+ seconds, then unplug the wall charger (while still holding the power button) and immediately plug it back in. The blue light should turn back on if it short-circuited due to moisture/overheating/miscommunication problems, etc.
Plantronics 903 Users Guide
Good Luck from Headsets Direct!
Jun 27, 2011 | Plantronics Backbeat 903 Bluetooth...
My Acer Aspire One D255 will not turn on. Light shows blue then immediately goes off. Won't boot on or anything.
Make sure that you have a charge. Try plugging it in and turning it on. If it still doesn't work then you might have a low battery, bad charger, or there could be a problem with the power supply. A bad charger and or a bad power supply would require replacements. You can probably find the charger at best buy or newegg.com. The power supply could probably be found at newegg.com. You might try taking it to a local electronics store and see if they have a different charger they can test it with, that way you would know for sure it isn't the charger.
May 03, 2011 | Acer Aspire One Netbook
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
take the battery out and try powering on your computer only with the power cord plugged in
if the computer turns on then
this is the problem with the battery
you need to replace the battery
Thank you
Jan 06, 2011 | Dell Inspiron 1545 Notebook
My phone was working at night, I plugged it into the wall charger while it was still on. I woke up the next morning, disconnected it from the wall charger, and the phone immediately shut off. I plugged it...
Dear Anthony,
It seems that over charging has damaged your gadget's motherboard or battery mechanism. You have to get it serviced. But still you can try by Removing your battery for 1 hr and then after re insert.
Jun 06, 2010 | RIM BlackBerry Pearl 8100
Pinnacle Video Transfer: at REC, all lights turn red--except USB
how about deleting all the software of that device and reinstalling it as a new device.
the program may have corrupted the flash drive and all the data that is on it and when you pluged into any other device it may of worked a few time but that it will start corrupting everything you have plugin your flash drive into.
you are going to reformat the flash drive and re install any type of drivers for the flash drive and check every where you have used the flash drive has not corrupt any of the systems you are using.
let hope we got it before you loose your intire system due to corrupted software downloads or uploads to flash drive and computer system and this may include a network if you are on one.
rod
Feb 27, 2009 | Pinnacle Video Transfer
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Aug 29, 2008 | Universal Remote Control MX-3000 LCD...
HOW TO INSTALL A MOTOROLA H550 BLUETOOTH HEADSET
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
Jun 18, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Samsung WEP-150 Wireless Headset Logo
231 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Ed Nelson
Ed Nelson
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
