Question about Electrolux E23CS75SS Air Conditioner
I have an electrolux split system airconditioner model no.EJE24HRA it has not been used for months but the display panel is suddenly flashing Auto and if I do turn it on it suddenly switches itself off after about 30 seconds and can't turn it back on won't do anything
  • 3 Answers
There is a auto switch button inside the indoor unit just above or on the side of digital display but you must open front panel to get access to it when you do, press that button which says auto once to cancell it from coming on than set your mode on the remote to heating then press start or on button on remote. be sure to set temp to atleast 30 degree before starting it
Posted on Jul 10, 2010
I HAVE AN ELECTROLUX KELVINATOR ESG21HRIA SPLIT SYSTEM,
do you have the user manual?? i am in desperate need for this!
Mar 10, 2012 | Electrolux Heating & Cooling
I have a R410A Inverter Split system that has stooped suddenly and is now displaying E1, what does this mean/ Thanks Lorena
Not 100% sure but an E1 error on a unit which is sourced from the same place as Electrolux air cons, means that the pipe sensor on the indoor unit has failed. You will need to confirm this with Electrolux. They carry a 5 year warranty, so you may be in luck.... hopefully
Jul 16, 2011 | Electrolux Heating & Cooling
How do I get my WR 100 ft model # AW60724W off army time.
  1. Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  2. Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  3. Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  4. Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  5. Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
Aug 31, 2010 | Watches
F8 error
F8 on tamashi ac
Jul 03, 2010 | LG Heating & Cooling
How to clean the filters in split airconditioners
Check on top of the indoor unit. On some models, the filter will slide out from there without having to open the cabinet. On others you will need to pull on the top front and the panel will swing down (it will be hinged) and the filter will be behind that panel.
Mar 24, 2010 | Heating & Cooling
MANUAL OPERATION OF SPLIT SYSTEM AIRCONDITIONER
In every model there different location of manual button. Some manual button are located in front of the indoor and some are at the back of the front grille near the control board.
Jan 24, 2008 | Heating & Cooling
Heating & Cooling Logo
546 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
