Question about Sony Playstation 3 (PS3) Console
My ps3 won't work with rca jacks
Every since i wired my ps3 through hdmi cables, it won't work with my rca jacks. how can i fix this?
  • 344 Answers
When you use the HDMI cable the system becomes automated, it detects that the HDMI cable is in use and with your help it sets up your audio and video.
RCA or Composite cables (same thing) are basic and dont communicate, so you have to go to your system settings in the XMB (cross media bar) and look for video settings, change them back to composite, and do the same for your audio. If that is too much work for ya you can do a master reset of the system. Hook the system up using your RCA cables while the system is powered off, then turn the system on wait 30 seconds and then hold your finger on the power button until it beeps twice, this will reset the system to its original settings
Posted on Sep 27, 2009
  • leanthony_ho Oct 30, 2010
    Thank Bro,
    I followed your instructions and I have my PS3 working again. I did step 1 without the reset.
    Thank you again
My ps3 wont work either i think it is because i turn off the main power button behind the ps3 too many times i use hdmi cable and when i trying too turn it on again it cames sound and picture but not the hud is it somebody as now what i shall do
Posted on Oct 04, 2009
Why will my ps3 not workwhen conected via multi-av cable to the RCA jacks?it does work conected to a hd tv via hdmi
When you use an HDMI cable with your PS3, the system is outputting the signal in a digital format. You need to tell it to switch back to displaying in an analog format to use the RCA jacks, otherwise it won't work. To do this, turn off your PS3. Then, once it's off, press and hold down the power button on the system. After a few seconds, it will beep and reset the output signal back to analog. Just make sure only your RCA cables are plugged in when you do this. Hope this helps!
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
PS3 shows a blank screen when I use the RCA jacks but works well when watching DVD movies when using a HDMI cable. When using the HDMI cable the sound is distorted whe I insert a game disk
Well heres the problem when you set your ps3 to be on 1080p using a hdmi cable the rca jacks wont work. to reset it power down the console. Then hold your finger on the power button you will hear it beep twice i believe rca jacks should be working now you will have to do that everytime unless you change it with hdmi cable plugged in to where you can see.
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
Will a ps2 audio video cable work for a ps3?
Probably not since the most common cable to use id the HDMI the newer televisions will not have the RCA video jack
Sep 17, 2010 | Sony Playstation 3 (PS3) Console
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Oct 31, 2009 | Yamaha RX-V363 Receiver
Ps3 works on hdmi but not on rca jacks ???
Sometimes its a pain to re hook up the cords if you are stuck in HD mode and tryin to go back to Regular or Vise Versa, power off the ps3 press and hold the power button for 3 seconds. that will switch the video card back to default settings.
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
No picture, only sound through HDMI port
You have the video [yellow cord] on the wrong rca jack. Or a bad video cord. Should be easy to fix.
Mar 24, 2009 | Sony PlayStation® 3 (60 GB) Console
I want to hook up external speakers to my Acer H213H for when my PS3 is hooked up to it.
What method are you using to connect to the monitor?
If you are using the HDMI -> DVI adapter it does not support sound. HDMI does, but DVI does not.
If that's the way you are set up then all you need to do is use the HDMI -> DVI adapter for your video and use the regular RCA connections for audio.
You can set the video and audio settings in the PS3 with the "Display Settings" and "Sounds Settings"
That way you just use the red and white RCA ends to connect to a speaker system, the yellow won't be in use at all.
Dec 10, 2008 | Acer Computers & Internet
I can't get any audio from my PS3 through the HT-R550 I am trying to set up in my home. I have an HDMI cable connected/running from my PS3 into the reciever. I also have an HDMI running from my Plasma TV...
run everything to receiver each channel should work on own for audio
video to tv audio to input rca jacks
if have to much rca's for little bit of reciever input output rca's go out to walmart and buy a rca switch for sound
one side would be A the other side would be B
May 13, 2008 | Audio Players & Recorders
No power on PS3
I THINK YOU NEED TO BUY NEW RCA JACKS,, BECAUSE IF THE ELECTRICAL FUSE WENT FROMT HE TV TO RCA JACKS THEN ALL THE CORDS THAT PLUGS TO THE PS2 ARE SHORTED OUT.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
2,979 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
