Question about Apple iPod nano
CANT REMEMBER THE CODE TO UNLOCK VOLUME LIMIT IS THERE ANY WAY I CAN RESET IT
CANT REMEMBER THE CODE TO UNLOCK diplay asks for code when ever i switch on
Posted on Sep 28, 2009
My sister locked his tablet with a password and now he cant remember what the unlock code is. its the type of code you unlock by making a pattern with your finger.
You have to reset it to factory default just follow those steps:
1. shutdown the tablette
2. hold volume up button and press the power button
3. when manufacturer logo come realise the power button but keep hloding the volume button to get into recovery mode
4. in recovery mode use volume up/down button to navigate and the power button to select
5. choose WIPE DATA / FACTORY RESET than select YES .... wait a moment then select WIPE CACHE PARTITION
6. finale step select REBOOT
keep in your mind the all data in the phone will be erased (apps & games)
ALL DONE!!!!
Mar 05, 2015 | Proscan 7-Inch Android Internet Tablet,...
ALL DONE!!!!
Volume limit password reset on ipod nano
Hi
How to Unlock iPod Volume Limit
Your iPod volume can be limited, and in many instances, a PIN number will be necessary to remove the limit. If you've forgotten or misplaced your PIN, you can still unlock your iPod volume limit using your computer.
1 Connect your iPod to your PC. Make sure your hidden folders are visible.
2 Navigate to the "iPod_control" folder. This will be a hidden folder. Once you've found the "iPod_Control" folder, navigate to the "Device" folder.
3 Locate the file named "_volumelocked" in the "Device" folder. Delete this file.
4 Eject and restart your iPod.
5 Navigate to "Settings" on your iPod. Select "Volume Limit." You'll be able to reset your volume limit with a PIN or password.
Tips & Warnings
Do not listen to your iPod at high levels for long periods of time; doing so can damage your hearing.
Nov 23, 2011 | Apple iPod nano
How do yu unlock an ipod volume that yu may have put a code to.. or yu may have not put a code to
On your iPod go to Settings, then Music, then Volume Limit. You can change the volume limit there. If you have locked it and cannot remember the passcode, you will need to do a hard reset, which will result in you loosing your data, but you will be able to restore it with your synced computer.
Hope this helps,
Thomas
Apr 07, 2010 | Apple iPod touch
I cant remember my password and need a unlock code sanyo spc-2700
Usually the code is the last 4 digits of your phone number. That's how they have it set up for the most part
Feb 08, 2010 | Sanyo SCP-2700 Cell Phone
Dont know the code to unlock my ipod screen and volume limit
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you cannot remember the passcode, you will need to restore your device using the computer with
which you last synced it. This allows you to reset your passcode and resync the data from the device
(or restore from a backup). If you restore on a different computer that was never synced with the
device, you will be able to unlock the device for use and remove the passcode, but your data will not
be present Follow the steps that i have outlined below. If this does not completely help your situation please
let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features
again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please note
that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is
to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Jan 04, 2010 | Apple iPod nano
I forgot my volume unlock code on my ipod 80gb
Oh dear. Connect your iPod to your computer, open iTunes and click the (Restore) button. This replaces everything on your iPod with new stuff from iTunes. You will be able to reset your volume limit code but use something that's easy to remember like your postcode
Nov 26, 2009 | Apple iPod nano
Ihave a kyocera phantom cell phone i cant remember unlock code
go to nearest kyocera service center and unlock
Aug 26, 2009 | Cell Phones
Volume limit lock how do i override the it ?
If you know the lock code, you should be able to unlock the volume limit by following the menus under Settings. If you don't, then some technical work is needed. Instructions are here: http://www.wikihow.com/Unlock-iPod-Volume-Limit
Aug 15, 2009 | Apple iPod nano
Volume limit unlock code
Apr 17, 2009 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
175 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
