Question about Dell Computers & Internet
TRINITRON DELL: VGA cable pinout, what color
TRINITRON DELL: monitor cable pinout, what color wire goes to which pin
Made in year 2000 (February)
(Manufacture inside the plastic cover is however Sony)
Unknown wires are: Green, Black, white and braun.
wire pair: red & yellow
ErusTownsend
  • 592 Answers
SOURCE: VGA Cable disconnect form the
here is the basic vga pinout
Posted on Jun 29, 2011
jemmyrash
  • 180 Answers
SOURCE: Missing VGA Cable for LCD Monitor - Help?
It should be 15 pin connector VGA .It should work.
Posted on Apr 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: VGA Cable Wire Colors
I don't think and RGB cable will work with a VGA cable because the signal in the video card is completely different. It's not just the picture but the scaning and refresh rates are totally different. Even if you could wire one it probably won't produce a picture.
Posted on Jun 30, 2008
  • 68 Answers
SOURCE: Emachine monitor lose color.
HI Bernard,
This sounds to me like the video lead is loose. Could you please try the video lead each end and tighten the locking screws if possible.
Regards
Nick
Posted on Oct 29, 2008
  • 252 Answers
SOURCE: i need a monitor cable pinout, what color wire goes to which pin
http://www.real-knowledge.com/videopin.htm
Posted on Sep 02, 2009
CRT VGA cable pin color problem. I can not get which pin connect where
Refer its connection diagram. The user manual might help you. If not, contact any service technician.
Nov 25, 2014 | Philips Televison & Video
Want to connect 40 pin LCD ribbon cable to the 15 pin D type VGA
VGA pinout?
Not a prob,
http://pinouts.ru/Video/VGA15_pinout.shtml
Pinout of that 40 wire LCD ribbon cable in your hand?
Dunno
Each manufacturer is different.
IF, you find the pinout of JUST THAT LCD cable you have, LET ME KNOW.
Post back in a Comment, or click on Reply at the end of this solution.
Regards,
joecoolvette
May 12, 2013 | Computers & Internet
Hello, The VGA cable broke. it was cut off and now it's lost. I can put back a VGA connector however I need a wiring diagram so I can know what color goes to which pin. Can you help? Thanks.
Not knowing which monitor that you have I will have to be a bit general. If the cable disconnects from the back of the monitor then you can simply replace the cable with another vga cable. If the cable does not disconnect then my best advice is to look at the other end of the cable and get the pin out from the controller board on that end. Unfortunately that procedure would require opening up the monitors case.
The above link will also help as a reference. However keep in mind that some of the colors may not match. Which is why you would need to check the other end of the cable to be sure. Good luck.
Aug 25, 2010 | Computers & Internet
Vga cable color code of 17" monitor of samsung SyncMaster can u send color code pichear
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the 5 - DDC Return 10 - GND-Sync/Self raster 12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
Aug 03, 2010 | SAMTRON 55V 15" CRT Monitor
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
Aug 29, 2009 | Computers & Internet
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
http://www.interfacebus.com/Design_VGA_PinOuts.html
More monitor pinouts,
http://www.montest.com/technote.html
Apr 21, 2009 | KDS K717s 17" LCD Monitor
Dell Trinitron Ultra Scan Monitors
Yes as long as your monitors have the standard 15 pin Mini D-sub connector (which they do) then you should have no problems viewing a composite input through your converters.
Jan 04, 2008 | Dell Ultra Scan 17TX - 17" SVGA Color...
Computers & Internet Logo
522 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
