Question about Nokia 7370 Cellular Phone
When i place sim card in nokia 7370, the menu does not come up. it also does not store the date and time that i set.
zaids
  • 456 Answers
SOURCE: security code of nokia 7370
Nokia MasterCode is:
0731416475
Posted on May 23, 2008
  • 4 Answers
SOURCE: everytime i have to set the time & date
Its because your battery is removed.......to keep the date and time intact there must
be some extra charge to keep it going like CMOS battery in computer...
If your battery is removed then the clock will be reset....
Posted on Feb 23, 2009
Murphybanton
  • 2004 Answers
SOURCE: Asking for security code when inserting sim card
Your master code is 7476642411.
Please rate this solution.
Posted on May 22, 2009
  • 31 Answers
SOURCE: My N95 8GB keeps asking me for the time and date
hi... u jus go to time settings an keep on th update time an date on... so that u can recover from this prob... kindly rate me... thank you....
Posted on Jul 01, 2009
  • 83 Answers
SOURCE: sim card
If you remove the battery cover and the battery, the SIM holder is right at the bottom of the phone - it is a little hatch that you have to swing up after pressing up the latch at the bottom.
Posted on Jul 06, 2009
Nokia 6350 1dr restriction code
Hi
Dial using the keypad: * # 06 # - IMEI number is displayed on the display.
SimClock
Allows you to check whether your SIM-card mode StopClock. When transferring the card to this mode significantly reduces power consumption and thus increases the work of the battery. Generally, all modern SIM-cards support this mode.
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display (operator logo).
*#0000# To view software version.
*#2820# Blue tooth device address.
*#746025625# Sim clock allowed status.
*#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that support WLAN
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
Displays Serial Number.
Displays the Month and Year of Manufacture
Displays (if there) the date where the phone was purchased (MMYY)
Displays the date of the last repair - if found (0000)
Shows life timer of phone (time passes since last start)
ttt
txexixs
Feb 27, 2017 | Nokia Cell Phones
Please help
HELLO!!
Guess the sim card is outdated !!!
Feb 29, 2008 | Nokia 7370 Cellular Phone
Tip
Nokia Tips
`Your Nokia cell phone can be programmed to pick up radar speed traps, when programmed your cell phone picks up the radar and alerts you on the message alert tone. 1. Enter your menu 2. Select settings 3. Select security settings 4. Select closed user group 5. Select on 6. Enter 00000 7. Press ok 8. Clear back to normal, within a few seconds your phone will display a radar sign with five zero's next to it. It is now activated. Unfortunately only Nokia phones have this function. Cell info display needs to be de-activated. Settings -> Phone Settings -> Cell Info display Each time you turn off your phone, or even each time you loose contact with your carrier, you´ll have to activate it again... It is done by steps 1 through 5, but the number (00000) will be already on the field as default. If you put the number 500 in the closed user group, and you go out of a store with detection ports thy will go off. Firmware version: *#0000# *#51x0# or *#9999# View Serial No., Date Made, Programming Date, Repaired: *#92772689# Thanks to Ben-Dov for this code IMEI (International Mobile Equipment Identity) Code: *#06# Enhanced Full Rate (EFR): *3370# to activate EFR. Makes calls sound better, but decreases battery life by about 5%. #3370# to deactivate EFR Half Rate Mode (HFR): *4720# to activate HFR. Decreases call quality but increases battery life by about 30%. #4270# to deactivate HFR. Default Security Code: 12345 Warranty Code: *#92702689# [*#war0anty#] asks warranty code. You can then type a number of codes (Thanks to Mike Pfaff for these codes): 6232 - Display date of manufacture 7332 - Display date of last repair 7832 - Display purchasing date 9268 - Display serial number 37832 - Set purchasing date to MMYY 87267 - Confirm Transfer, Related to firmware upgrades #746025625# says SIM CLOCK STOP ALLOWED or similar, depending on your SIM card. Newer SIMs have a feature called 'clock stopping' that allows the phone to save energy -- it is a kind of sleep mode for SIM cards. Not all versions of software support this. You cannot turn the SIM clock on and off, the phone will do it automatically if the SIM supports clock stopping.
on May 20, 2010 | Cell Phones
Tip
Nokia
1. Enter your menu
2. Select settings
5. Select on
6. Enter 00000
7. Press ok
Firmware version:
*#0000#
*#51x0# or
*#9999#
*#92772689#
*#06#
12345
Warranty Code:
on Dec 09, 2009 | Cell Phones
Nokia 7370 bluetooth problem
Welcome to Fixya
Dear USer
Try a Factory default Settings to Your Phone through Settings Menu.OR Enter *#7370# or*#7780# .Type Code [Default Code is12345].
Still have Trouble your Bluetooth IC might be Damaged Need to be Replaced...
Hope you got it...Thanks for Connecting FixYa..
Sep 03, 2010 | Nokia 7370 Cellular Phone
SIM card not valid
1. try to format ur set *#7370*
2.If stilll having problem then go to repair centre. ur ic or pbc may be damaged wont cost u much
Aug 03, 2009 | Nokia N70 Cellular Phone
HELP!!!!
go into your you phone book settings and change the setting to save on sim card and that should automatically save them there then there's another setting where you can copy all the contacts saved on the phone to the sim to save putting all your contacts on the phone again hope this helps
Sep 29, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Formating
my shoud not the format code is not accepted
Sep 04, 2008 | Nokia 6681 Cellular Phone
Master code for all nokia 3110
Nokia Unlock Codes, Nokia Phone 3110 Secret Codes, Cell Phone Codes
Nokia 3110 Secrets
*#06# : Checking the IMEI (International Mobile Equipment Identity)
*#7780# Restores Factory Settings (Memory, language, counters are not included).
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#746025625# [*#sim0clock#]
Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
Press the following warranty code :
6232 (OK) : Displays the Month and Year of Manufacture (0997)
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it. The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove SIM card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
NOTE : These codes could be used with care. A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIM locked to one provider you can bypass the SP lock like this:
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key.
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed
Jun 10, 2008 | Nokia 3110 Cellular Phone
Please help me with NOKIA 7370 and SONY ERICSSON Z520
sir your sim card is not registerd by your sim card opretor and show your sony phone to mobile repair shopee
Nokia 7370 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
