Question about Nikon Speedlight SB-600 TTL Flash
SB600 beeps multiple times and picture comes out under exposed
I was shooting and the flashes started beeping and the pictures were coming out under exposed.
    Genius:
  • 1,689 Answers
The beeps are probably an alarm telling you that there is a setting fault.
Read the instruction book for both the flash and camera to properly set things up.
Generic comment:
Check all the settings to make sure that flash and camera are in the proper modes. Start by putting both in "A" (automatic), and work from there.
Jerry G.
Posted on May 17, 2008
When taking a picture in daylight and the background is bright the background comes out as white-no colour. I've tried fill in flash and also exposure compensation to no avail. Very frustrating-please...
Your camera is setting its exposure to your subject, which if it's darker than the background will cause the background to over expose. You need to set the exposure to the background which then will cause your background to be properly exposed and your foreground or subject to be darker. With a point n shoot camera, accomplishing this might be a difficult task. But if you expose to the background and use the fill flash, you should then get your properly exposed image.
Jun 04, 2014 | Nikon COOLPIX S5100 Digital Camera
Treaks when shooting pictures in sunlight with Sony DSCW-510 Camera
When shooting into the sun your subject tend to ubder exposed.
Shade the lens so that the sun does not fall on the lens (get someone to shade the camera with a hat), turn on the flash gun use it as a fill in flash.
May 03, 2012 | Canon Cameras
Whenever I'll take a picture specially in outdoor enviroment, when I download the to my computer it seems the picture has so much light appearance. It's seems picture is over expose for the light...
It may be that you have inadvertently set your camera to shoot 'bracketing up' - ie over exposing for every shot. You need to look at the exposure ruler which looks something like this: l---l---l---l---l The centre bar is the correct exposure. But there is a little block that sits where you have got your +/- setting at. +/- is the sign for BRACKETING - where you tell the camera to over expose (+) or under expose (-). With Canon if the little block is to the right of the centre bar then you are telling the camera to over expose. Where is your little block? If it is to the right of the centre press your +/- button and turn the dial to the centre bar. NOTE: As digital cameras are WEAK in capturing highlights it is often better to shoot slightly under exposed - with your block set on the first or second horizontal line to the left of the centre bar. This means you are shooting 1/3 or 2/3 of an f/stop under exposed. Hope this helps.
Dec 31, 2010 | Canon PowerShot A470 Digital Camera
I have recently shot some pictures with my canon 580 EX flash. pictures seemed to be a bit underexposed. My camera is a 50D pictures shot at ISO 200. The lens was a canon 17-40 F4 L. Is is possible that...
It all depends on the environment you're shooting in. When shooting a wedding reception for instance inside in the evening I will generally use ISO 800 and I quite often use FE Lock which is very handy. FE Lock will pre-flash the speedlite and meter the result based on the center focus point in your viewfinder (it doesn't matter if you have set another focus point it will always meter to the center one so make sure that is over your subject when you use it). To use FE Lock press the button near your thumb that has the * symbol with the center focus point over the subject. You can then re-frame the shot if required and take the picture. The camera will take the picture based on that flash setting and you should find that the shot is better exposed.
Nov 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
Flash is delaying
The self-timer is on. Press the button on the back of the camera to the right of the displays just under the AV button. The display icon will change from :-
Hand sweeping round clock = self timer mode
Simple square = single shot mode
Stacked squares = multi shot (keep finger pressed to keep shooting)
Jan 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
I have a sony cybershot DSC-T70 when I try to use the flash it doesn't work. When I touch the screen 4 options are supposed to come up and nothing appears except for the one that says no flash. I was...
the flash icon will also be disabled if the camera is in burst or continous shooting mode-if possible restore camera to factory defaults and start from there-check in home menu under shooting and see what the settings are
May 21, 2008 | Cameras
Indoor picture too dark with flash
Hey Jewdeit,
The built in flash on the K100D has guide # of 52 at iso 200 which does fine for close-up photography and as fill flash outdoors, but is not a powerful enough flash for shooting far away subjects indoors. What you probably should do is purchase an external shoe mounted flash such as the AF540FGZ which has a much higher guide number of 148 at iso 100. When shooting with flash if you are using aperture priority or full manual you can also try opening the aperture to let in more light that the flash put out, but doing this might over expose anything in the foreground.
Sincerely,
Allan
Go Ahead. Use Us.
May 06, 2008 | Pentax K100D Digital Camera
Nikon Speedlight SB-600 TTL Flash Logo
246 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
