Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
My battery is not charging on my motorcycle - Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Most battieries are only good for about 3 yrs. i highly recommend you keep it on a battery tender one you replace it. a tender will monitor the level and if it drops to 12.0 it will recharge it back to 13.4 or so. check your charger too as the new batteries can only take a 2 amp charge or you will fry it.my advise is take the battery out and bring it to the local h-d dealer. they will put it on charge overnight and test it in the morning. very possible it is bad and time for a new one. however, if the battery is new but keeps draining while riding then your stator is probably gone.
Posted on Oct 06, 2009
    Scholar:
  • 150 Answers
Then u need a new stator and or regulstor. If u change a stator always put a new regulator on.
How long do i charge ever start 16b battery after filling with acid
Hi Anonymous, the "ABSOLUTE" best way is let the battery acid soak into the plates for 1 hour then connect a 1 or 2 amp trickle charger and let it charge for 24 hours for maximum battery life. Read my lips "DO NOT" use a higher rate charger for less hours it will shorten your overall battery life, trust me I was a Harley technician for over 40 years. For more information about your issue please click on the links below. Good luck and have nice a day. BU 403 Charging Lead Acid
Fill and Charge Motorcycle Battery
How to Charge Motorcycle Battery
Battery Basics Layman Guide to Batteries
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 15, 2016 | Motorcycles
How does the charging system on a 1969 Honda 325 cc motorcycle work to keep engine running?
I think you mean a 69 CB350. It sounds like you have a bad battery since the battery charger won't charge it.
On this bike there is an alternator and rectifier that combine to charge the battery whenever the engine runs. If the battery won't hold a charge, the charging system wont work.
Replace the battery.
Sep 26, 2014 | Motorcycles
Motorcycle battery charging
Use a trickle charger no more than 2 amps. Initial charge will take 8-16 hours if done this way. The dealership can put a service charge on it which usually takes an hour, but I have found that the battery doesn't last as long this way.
Aug 20, 2014 | Honda VT 1100 C Shadow Motorcycles
How to charge a new motorcycle battery
New Battery charge at 2 amps or lower overnight for best results. However a quick charge enough to start the bike is fine as long as you ride it for a good hour to charge it and stabilize. I would just charge overnight though.
Aug 18, 2014 | Motorcycles
New stator and regulator flat battery after journey
What model motorcycle motorcycle is it. I have had a simular problem one time with a customers motorcycle customer brings the bike in for the same problem i charged the battery then checked the charging all normal could not find the problem so asked the customer to take it for a ride being he lived close to the shop it did it again he brought it in and checked it it was charging normal so i just let it run and heat up checked the charging no charging. It was the stator when it hit a certain temp it stopped working you may want to try the same test.
Oct 26, 2012 | Triumph Daytona 600 Motorcycles
Motorcycle is not starting without battery
no the newer bikes will not start whitout a full charged battery in the circiut if the battery is not charging you need to get a mecanic to check the stator it is propably shorted out
Aug 07, 2012 | 2006 Bajaj Discover DTS-I
Wont turn over
First thing always is charge the battery. The top of the battery reads the proper amperage, and motorcycle stores will push their trickle chargers, or battery tenders, which won't actually charge it. Please make sure you disconnect the battery before you charge it.
Jul 09, 2011 | 2004 Aprilia Atlantic 500
Starts good with a jump from other battery ,but when i take cables off my motorcycle then trunes off.
Battery and/or charging system is not good. Put charger on battery, bring to full charge, then put load tester on battery ensuring battery not weak or a dead cell. If battery is good, check charging system.
Apr 15, 2011 | 1991 Yamaha FZR 1000
Lands Phones Logo
245 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
