Question about Dell 1710 Laser Printer
I cant seem to make the printer stop printing front and back pages, i have an entire **** of paper here with the big arrow on it with the 2 sided printing instructions
  • 615 Answers
Send me your email address to alenorm@yahoo.com as the instructions taking more than what is allowed in this post. let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 27, 2009
I use a CM2320nf MFP connected to Windows XP. The unit seems to be defaulted to print 2 pages - and for double sided copies, it stops after 2 pages, then the Cleaning window pops up, then I get an error...
Problem 1 :
As far as the machine printing 2 pages per job. To fix this it's usually the default number of copies the printer is set to. To change/ confirm the setting is set to one:
Press the menu button
Arrow down to -> Printing, Press the green check to enter the menu
Arrow down to -> Copies Press the green check to enter the menu
Change or confirm the value = 1, (Based on your question this might be set to 2) Press the green save the value.
* If your number of copies is set to 1 and the machine is still printing 2 copies, then the problem relays in your print driver.
Problem 2: General Misprint Error message something like 41.3
2 things to check:
1st - Press the menu button
Arrow down to Paper Handling, Press the green check to enter the menu
Now you will see options like Tray 1 size - Tray 1 type. Here their will be a option for each tray installed on your machine. You will go into each tray option and confirm the paper size and type.
Example
Tray 1 Size = Envelope #10 (This is the manual feed tray)
Tray 1 Type = Envelope
Tray 2 Size = Letter
Tray 2 Type = Plain
To perform arrow down to tray X size press the green check to access the menu, arrow up or down to select your paper size. Once the paper size is selected press the green check to save it. repeat for each tray.
2nd -
Pull out your tray and remove the paper, towards back of the tray you will see a guide (Tab) in the middle of the tray which allows you to expand the tray to accept various paper sizes, Please confirm the guide is set to the correct type. If your using letter, make sure the guide is set to letter (LTR) you can see these codes by looking at the base of the guide, their is a little arrow pointer.
Hope this helps
Jan 14, 2011 | HP LaserJet 2420 Printer
Smear on right side of paper entire length of paper all colors
Follow the below instructions to clean the printer through the control panel:
  1. Press MENU to enter the MENUS .
  2. Press (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press (Select) to select CONFIGURE DEVICE .
  4. Press (Down arrow) to highlight PRINT QUALITY .
  5. Press (Select) to select PRINT QUALITY .
  6. Press (Down arrow) to highlight CREATE CLEANING PAGE .
  7. Press (Select) to select CREATE CLEANING PAGE . A page with a pattern prints from the printer.
  8. Remove all paper from Tray 1.
  9. Remove the cleaning page and load it face-down in Tray 1. NOTE: If not still in the MENUS , navigate to PRINT QUALITY using the above instructions.
  10. At the printer control panel, press (Down arrow) to highlight PROCESS CLEANING PAGE . This option will only be visible in the menu when a cleaning page has been printed.
  11. Press (Select) to select PROCESS CLEANING PAGE . The printer control panel displays the message Cleaning... . The cleaning process takes a few minutes.
let me know ....
If I could be of further assistance . If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | HP Color LaserJet 3500 Printer
Black spots lined up on page - cleaning sheet didn't help
To tell if it's the fuser you can do a half way test, what you have to do is print a document, and open the front door of the printer to stop the print job half way through, you should see that half of the toner is fused to the paper and half is just applied to the paper, if you see the black lines on the fused side of the page its the fuser if you see it on the entire page it could be the etb or the cartridge.
possible fix:
This is a common issue with laser jet printer,
Try running cleaning modes under the service menu on the printer, run 5 back to back. if the issue is still showing, try using a different cartridge and run the cleaning mode again. If you have an old cartridge even if its close to being empty you can do an override on the printer to test the cartridge:
1.press ok
2.use the arrows and navigate to the system set up menu
3. press ok
4. print quality
5. press ok
6. override out
7.press ok and again ok to set
This could also be a build up of toner in the fuser assembly, and you may have to adjust the fuser temperatures in the embedded web server. You can print a blank word document (20 pages) and see if you still see black dots, if you do it is likely to be the fuser, set the driver and printer settings to card stock or heavy in order to heat the fuser more than the usual temp and print 30 blank pages this should resolve the issue. if this does not there could be damage to the ETB or the fuser assembly and servicing of the printer would be required.
take care,
Al
eliteprintersolutions@gmail.com
Dec 11, 2009 | HP Laserjet Cp2025n Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Flashing orange arrow . cant get anything to print
Try taking out the print cartridges and then putting them back in and make sure they are really well inserted when you replace them. Then slam the lid down to really make sure its shut and it should resolve the problem.
Apr 02, 2009 | HP DeskJet 5150 InkJet Printer
Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Feb 13, 2009 | Xerox Phaser 8560DN Laser Printer
Print from memory
if you still have the paper manual it's on page 54 and 55
basically you have to press fax button, then press the menu button, then use the right or left arrows (on the side of the ok button) to select "memory reference" then press "ok", then press the arrows again to print which document in memory you want to print (usually the most recent is listed) then press "ok" again.
finally press the arrows to select "yes" to print only the first page or "no" to print the entire document and press the ok button one last time. it should print.
if you are still receiving a "change paper size" type error, go ahead and press the fax button, then the settings button, use the arrows to select your paper size, press ok, then select media type, in this case "plain paper" and press "ok"
that should do it.
Sep 05, 2008 | Canon PIXMA MX310 All-In-One Printer
Cannon MP160 How to Print both sides of the Paper???
Set Duplex Printing (Windows) For details on how to set duplex printing, see below: 1. Select 'Properties' from the Print dialog. Note: Properties may be indicated as Advanced, depending on the application software. 2. Click the Page Setup tab. 3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'. 4. Select 'Duplex Printing'. Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed. 5. Specify Staple Side. 1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. 2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. 3. If necessary, click Specify Margin... and set the Margin width 6. When the setting is completed, click the OK button at the bottom of the window. Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side. If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages. 7. You will be prompted, while printing, to remove the printed page and reload it in the ASF. 8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed. Back to Top
Sep 10, 2007 | Office Equipment & Supplies
Dell 1710 Laser Printer Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
