Question about Yamaha Audio Players & Recorders
How do i connect graphic equalizer to reciever
    Novelist:
  • 169 Answers
A graphic Equalizer (GE) is acomprehensive tone controller which enables cut and boost over wide range of frequencies a Klark Technik DN27 was a mon unit and had 27 bands) And a DN22 was stereo with 11 bands /ch
They are called as named because when viewed from a distance they look like a graph of the sound.
Normally a GE is inserted into the signal chain between the pre amp outputs and the power amp inputs.
So look on your equipment for these rca /jacks. (pre out) (amp in)
It is possible to do the in /out fubctions on one connector (stereo jacks) so look for jacks marked insert point.
This will be a very suitable place for the GE connection.
Hopw this helps. thanks for using Fixya
Posted on Sep 28, 2009
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
I have a pioneer VSX D-308 RECIEVER and a electro-voiceevt 2210can it be hooked up together
The Tapco equalizer was a very popular line of equipment which was eventually bought up by Electro-Voice. Could not find any online manuals, however found online images of back panel. It appears to have Tape Ins & Outs.
Unfortunately the equalizer you have is not compatible with the receiver unless you have special cables that have built in transformers. This unit has T&R connectors (tip & ring) meant for professional sound equipment.
On a typical home stereo receiver you would hook up your equalizer with RCA connectors as follows.
1) You take the output of the equalizer and plug it into the input of the receiver.
2) You take the output of the Receiver and plug it into the input of the equalizer.
Start with lower volume and your tape switch on the receiver to the on position. Play with the various controls on your equalizer to
Apr 17, 2014 | Electro-Voice Tapco Graphic Equalizer,...
Ok I have an Onkyo HTS8409 Network A / V Home Theater System - 7.1 Channel, and dvd player and want to know how to connect a equalizer technics sh-GE70 but i dont have a cassete deck
Equalizer is connected in between the deck and the reciever. Deck into the input of the equalizer, and the out of the equalizer goes into the tape input on the reciever.
Sep 26, 2013 | JVC TD-W118 Single Cassette Deck
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
I cant seem to hook my pioneer gr 470 equalizer to my pioneer receiver ( vsx-403) what is the proper connection sequence?
tape out from reciever to line in on the eq --then line out from the eq to tape in on the reciever --whenever the tape monitor will be used on the reciever the sound will then be equalized
Sep 02, 2010 | Pioneer GR-470 Home Equalizer
I have a 300 watt amp, but i just bought 12 gauge wire why wont it allow sound to come from my 12'' sub
There is no reason even if the wire was to small it would still allow ssound.make sure you have good connections.
Nov 08, 2009 | Pyramid 906 300 Watts (peak) 10 Band...
Using graphic equalizer on a Pioneer CD player
try to connect it in tape in-and confirm that you select the right input in the receiver(in our situation you will select tape as input source).
Sep 14, 2009 | Audio Players & Recorders
Connect Equalizer to Yamaha receiver
You do this the output cord or RCA cord of your yamaha reciever is to input in your graphic equalizer ,the output of your equalizer is in to the speaker that all .. feel free for asking assistance for further question arises rate as fixya...
Jun 19, 2008 | Audio Players & Recorders
CONNECTING
you can do it passive. no idea with your ampli, but if it does have a bridge then you can hook your eq there, series. if it doesn't have then via tape monitor 2 of your kenwood.
onkyo recvr tape 2 record to - kenwood eq in
onyo recvr tape 2 playback - kenwood eq out
that's all. if you want your eq to be active, then switch your reciever to tape2, all selected input in your reciever will by pass through your eq then back to kenwood. you dont have a function for tape 2 input then but your eq will have an extra input for tape, that you can use for your second tape, it will be active only if your reciever is set to tape 2. i hope you got it right.
post back if you got it done
red
Feb 10, 2008 | Audio Players & Recorders
How to connect an equalizer
the monitor its basicaly the switch who connect or separate the preamplifier from the amplifier and that the part that you can connect the equalizer the only way it using an external preamplifier. sorry for the bad news
Jun 10, 2007 | Yamaha HTR-5850 Receiver
403 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
