Question about Canon PowerShot A460 Digital Camera
Camera will not communicate with computer - Canon PowerShot A460 Digital Camera
    Brigadier General:
  • 11,967 Answers
Use a card reader to download your pictures to a folder you create on your desktop.
Posted on Sep 28, 2009
The Busy light is blinking when I'm tying to download pictures onto PC, how can I fix this?
Did you first install the software on the computer, before you connected the camera to the USB connector? It is needed, so the computer knows what to say to the camera. Only then the camera can communicate with the computer.
Software, came on a cd with the camera, or they gave you a link where to download the software.
Apr 15, 2015 | Canon EOS 50D Digital Camera
The download from camera quit working
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 28, 2012 | UClear Bike Helmet Communicator
Camera says "communication error" when trying to transfer images to computer. Why?
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jan 10, 2012 | Canon G12 Digital Camera
I have been using my G11 with no problems for a year. Just tried to download pix and keep getting "Communication error". Checked the cord, it's fine, turned camera off and on several times,...
hi kbailey. Turn on the camera and go to the menu. find the reset function. Reset the camera. This means you are returning it to all of the settings it was at when it was brand new out of the box. Joe
Thanks for choosing Fixya!
Nov 26, 2010 | Canon PowerShot G11 Digital Camera
"communication error"??!
Use a card reader instead of the camera.
Jul 21, 2010 | Canon PowerShot G10 Digital Camera
Downloadind pictures
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. This is normal processing. The camera screen should shut off as the computer is now taking over to transfer the data from the memory card to the computer.
Jan 05, 2009 | Olympus FE-220 Digital Camera
Camera not communicating with new computer
I think that Canon has an update, there are differences between Panther (10.3) and Leopard (10.5) Check here at CanonUSA
Jan 27, 2008 | Canon EOS-5D Digital Camera
"Camera not connected." -- Serial connection
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 820 Digital...
"Failed to Connect to Camera." -- Serial connection
Sep 21, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
I am getting communication errors. Error Message appears in the display "Your camera or PC is not ready." (Fuji DS, DX and MX digital cameras only)
Most of the time the problem is due to the serial port setting of your PC. Please follow instructions below. Cause Camera is not communicating to your PC. Remedy Please check the following. 1. Cable connection. 2. Camera is ON and in PC mode. 3. Camera's batteries are not exhausted. 4. Go to Communication setting from "Camera" and make sure proper COM port is selected. 5. If your PC has external input device, disable its driver such as "Hot Sync" or similar drivers. 6. If your PC supports PS2 mouse, please use it instead of serial mouse. Then one serial port is available for the Digital camera. 7. Check in the BIOS Setup Screen to make sure the serial port of the PC is not disabled. Also, if your personal computer is equipped with an internal modem or infrared port, it may cause conflicts with port assignments internally that will not allow communication with your camera and PC. In such case, it is necessary to change the COM port setting for serial port. For details, see the User's Manual for your personal computer, or ask at the store where you purchased your personal computer
Aug 30, 2005 | Fuji DX-7 Digital Camera
Canon PowerShot A460 Digital Camera Logo
47 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
